Magic Chef CMV1000B Microwave Oven Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Maytag mmv4205baw Microwave oven. It
I have a Maytag mmv4205baw Microwave oven. It turns on and operates normally except it doesn't heat. Turntable works, lights work. It is louder than normal, we hear some snapping sounds, not unlike a electrical short.
Anonymous
Level 2:
Scholar:
  • Expert 130 Answers
  • Posted on Jan 15, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
130
Questions
0
Helped
352401
Points
292
The unit that creates the microwaves called the "magnetron" has gone bad, or the circuits powering the magnetron have gone bad. there really isnt a cheap way to fix it, and not a undangerous way to fix it yourself. if your really like the microwave and dont want to part with it, you can try finding a repair shop that will fix microwaves, but they will probably tell you it would be cheaper to buy a new one. sorry
Maytag microwave turntable doesn't operate
Does everything else work?? If so, its just the turntable motor, simple to replace. there are three or four screws under the bottom. UNPLUG the microwave first.
Double check before ordering...but ..
Here is the one you need:
Turntable Motor DE31 10172C
1helpful
Maytag microwave problem everything seemingly works but does not heat. Help
see this causes and fix it. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
3helpful
2answers
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
1helpful
Maytag microwave MMV4205BAW interior fan continues to run when door is closed
One of the micro switches has malfunctioned, and must be replaced for normal operation.
Maytag MMV4205BAW not turning
Change the turn table motor part # DE31-10172B
1helpful
Our microwave is buzzing load and there is a little flashing microwave in the lower left corner of the display any idea what is going on model MMV4205BAW ser 14597479LP
There are three things that will cause this, the magnetron "common problem" or the high voltage capacitor or diode. The above mentioned work together to heat the food and depending on the nature of the repair, parts and labor can approach the price of a new unit.
Display and touch buttons inoperative on MMV4205BAW Microwave Oven. Only abt 2 yrs old...
The keypad controller has probably developed a short in the membrane of the keypad, it must be replaced in order to get it up and running, but I suggest a maytag repairman to address this.
2helpful
Microwave no longer heats, makes more noise than it did when it was heating. Microwave is a Maytag, model # MMV4205BAW. Thanks.
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
1helpful
It is operating normally except not heating the food
The most common problem spot when the microwave will not heat is the magnetron. this is a device that produces the heating effect. you will need to replace this failed component. it has failed. Replace the Magnetron.
Top Magic Chef Microwave Ovens Experts
Jerry Naidoo
NOEL
NOEL
vince
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
