Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer sounds like an airplane taking off when in spin cycle. It is really loud.
PRIMOAPPLIAN
Level 3:
  • Master 401 Answers
  • Posted on Jan 15, 2010
PRIMOAPPLIAN
Master
Level 3:
Answers
401
Questions
0
Helped
106233
Points
1126
Its probebly the main bearing. disconect the power and remove the back. then slide the belt off the big pulley. if you see alot of brown splatter you know its the bearing.if not with the belt removed go to the front and open the door spin the drum fast, if it makes the same noise its the rear bearing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
31403
Points
17
Mine was really loud until we discovered the unbalance switch problem which caused my washer to stop spinning completely. We found that a block of stabilizer styrofoam was supposed to sandwich this switch between it and the wash drum had slipped out. Once replaced the washer was MUCH quieter.
  • myfeetstink Apr 15, 2011
    Hello - - I am in a jam and could use your help. I am repairing a neptune washer - - - front and rear bearings. When I opened the machine up I found a block of styrofoam sitting loose in the machine. I also found a small switch on the bottom of the washer floor (two blue wires connected to it). You elude to the block and switch.... I can't find info on how these items are supposed to sit in the washer anywhere on the web. Can you help me?
    My email address is [email protected]
    thank you in advance for your assistance
    Kerry
1 Related Answer
kapishtech
raj somaiya
  • 2272 Answers
  • Posted on Aug 30, 2010
SOURCE: Maytag Neptuen Washer makes loud noise when
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.Get the spin bearing and motor checked.Replace the faulty. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
1helpful
Maytag washer spins loud
Glenda, Is this a front loading washer? If so, you have a bad basket support bearing. A rather expensive repair.
1helpful
2answers
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
2helpful
Whirlpool washer WTW6400SW very loud spin cycle, sounds like airplane taking off
Most likely it is the spin tube bearing worn. Reguires some know how and special tools. Requires a major dismantle of the machine and usally I did these repairs in the shop. Bearing will eventually sieze over use and time. Labor will probably exceed the value of the machine.
2helpful
Maytag Neptuen Washer makes loud noise when spinning. Sounds like an airplane taking off.
9helpful
3answers
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
2answers
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Washer is extremely loud
defective back bearing and spin basket..onthejob
2helpful
Loud noise
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary
Hope it may help you;
Regards;
VOTIT
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
