There are three ways that you can use enable for you to transfer pictures from your cellphone to your laptop.
1. By using a connectivity cable. It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.
A connectivity cable looks like this.
2. Bluetooth. Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth.
CLICK HERE3. Memory Card
SD cards are used in many cell phones.
Many cell phones come with removable memory
chips, which can be used to expand the available storage on the cell
phone, or to transfer files (such as music and pictures) between the
cell phone and other devices. Once you identify the kind of expandable
memory in use on your phone, an adapter can usually allow you to connect
it to a laptop as if it were a USB drive.
Here's the instructions on how to do that:
1. Determine what kind of two-gigabyte memory chip your cell phone uses.
You can do this by checking the specifications of your cell phone in the
manual or on the manufacturer's website, or by removing the card and
examining it. As of April 2010, the most common kind of memory card used
in cell phones is the SD format, which comes in standard, mini, and
micro sizes. Your phone may also use the Memory Stick Pro or Pro Mini
format. The format type will be printed on the side of the card.
2. Purchase a USB adapter for the card you are using, which is available
from many different vendors. If your card is in a mini or micro format,
make sure that the adapter comes with a sleeve for the card of your
size; this allows you to insert a mini or micro card into the sleeve,
and changes the card into a standard size for use with the adapter.
3.
Insert the card into the sleeve, if necessary, then into the
adapter. Connect the adapter to a USB port on your laptop. The card will
appear on your laptop as if it were a USB drive. When you are finished
working with the card on your laptop, you can move it back to your cell
phone.
Hope this helps.
Please don't forget to rate this solution. Leave your comments or suggestions on how I can improve my service.
Thanks
