Ricoh Aficio 2232C Color Copier Logo
Posted on Jan 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Ricoh 2232c copier has displayed error SC374 can you tell me what this means?
Anonymous
Level 2:
Guru:
  • Expert 389 Answers
  • Posted on Jan 16, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
389
Questions
Helped
182229
Points
845
SC322 Laser synchronization error SC324 LD drive current over SC390 TD sensor error 1 SC374 Development bias leak SC393 TD sensor error 2 SC401 Transfer roller leak error 1
Ricoh Aficio 2232C Error Message SC393-02
I had the same problem after transit of copier. Try removing the yellow developer unit and give it a good shake. You may need to do it with the other units too.
My Ricoh 2238c color copier has a SC440-01 error, what can I do?
Main motor error
The main motor starts or changes
speed. The lock signal does not
continue for 1 second within 3
seconds.
• The main motor starts. The lock
signal is detected and operation
proceeds normally. The lock
signal is interrupted for 1 second.
Causes:
• Defective main motor
• Too much load of the main motor drive
RICOH AFICIO 2232C FUSER THERMISTOR
how do you reset the fuser on a savin clp 27 dn color printer (sc 545 code)
I have error fc 824-1401 on my ricoh aficio 2232c. i need help
Self-diagnosis error: Standard NVRAM The controller cannot recognize the standard NVRAM installed or detects that the NVRAM is defective • Loose connection • Defective standard NVRAM • Defective controller 1. Turn the main switch off and on. 2. Check the standard NVRAM is firmly inserted into the socket. 3. Replace the NVRAM. 4. Replace the controller.
I have a ricoh 2232c. Do you know how I can clean
In order to clean the optics, you have to remove the two optic covers (one over the **** glass on the left and one on the rear side of the main platen glass). Each cover should have 2 or 3 screws.
Clean the **** glass and platen glass with alcohol and a lint-free rag (both sides) and blow compressed air onto the mirrors, lamp, and reflector. It's a good idea to turn off the copier before doing this.
When reassembling, clean the white strip on the underside of the **** glass cover as well.
Describe your ricoh aficio 2232c manual copier internal tray problem solving Problem display screen says internal tray open [email protected]
just take a air blower and flow the area from where the paper comes out ur internal paper tray sensor is dirty
3helpful
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Ricoh Aficio 2232c printer without power. Need to
The main fuse is close to where the cord plugs into the machine. You can follow the wires, (black white and green) to an inline fuse or the main power board.
Gestetner DSC332 SC393-02
Hello klwhite,
The answer to your question:
Savin.......3224/3828/2820
Ricoh......2232c/2238c/2228c
The error code means that there is a problem with the yellow dev unit. The manual says that "during warm up" the TD sensor saw .78 volts or less when it performed process control. We both know that this device may perform process control at times other than warm up. Sounds like the yellow dev unit is the problem as the sc393 means td sensor and the 02 means yellow developer unit. I truly hope I have helped you. Take care.........spinal......
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
