Abit KN9 SLi Motherboard Logo
Posted on Jan 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Abit KN9 SLI on boot immediately goes to bios settings. Box is stripped down - video card one DVD drive and one hard drive. Set he boot sequence to CDROM and Harddrive try the rboot immediately goes to bios setup. No beeps or indicators
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 72 Answers
  • Posted on Jan 14, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
72
Questions
0
Helped
19352
Points
213
Ur mobo bios must be corrupted update it, this will solve the problem
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
Power Up
So after 5 seconds it won't come on again at all, or it runs for 5 seconds each time? What else do you have running on this computer? I'd suggest disconnecting all non-essential devices (hard drives, all but one memory chip, any expansion cards other than video) - if one of them has a short, they can pull down the power supply (regardless of the condition) and cause it to shut off exactly as you've explained. Let me know if that makes a difference (it obviously won't boot without a hard drive, but it will get far enough to see if that's the problem). If that doesn't make a difference, let me know and we'll try something else.
This is going to sound vague, but currently a friend and I are working to get this desktop PC working that has a KN9 SLI motherboard installed on it. Currently, the issue is: The computer turns on, a red...
Try checking the jumpers on the motherboard. A lot of the SLI compatible boards have jumpers that need to be configured properly. You can find out the positions by checking the motherboard manual. Are you using an SLI capable video card or is the video onboard? I just ask because I had the same problem once while trying to install an SLI video card. I had no picture on the monitor and I couldn't figure it out for the longest. Finally I found the answer in the motherboard manual and it turned out to be a jumper that was set wrong. Hope this helps.
Boot up does not load to login prompt. It loops after not detecting D1.D2.D3 and goes right back to the Start Windows Mormal prompt
you will have to change the boot sequence in the BIOS.
preee F2 or Del to enter the BIOS - you can change the sequence, set the first Boot 1 = DVD/CD, boot 2 = Hard drive
press F10 exit and save > ok
next time it will iuse the DVD/CD to boot first.
if you set the boot to b1 = Hard drive & boo 2 = DVD/CD......the hard drive boots
hope this help
merry xmass
Abit kn9 sli overheating ??
The problem could be a failed electronic component, and no cooling remedy will solve the problem. When some components fail, they result in high heat conditions.
1helpful
2answers
I just received a hand me down system with the abit kn9-sli motherboard. After installing a new amd 64x am2 6000+ processor and a new hard drive...when I powered on the system...the systemboard speaker...
Usually the sound is called bios beeps. They let you know in advance if there is a problem.
Usually a high low bios signal ( like an old german siren) means a cpu issue.
Check the processor and cooling fans, and check it's temp....take two aspirins and call me in the morning...LOL :)
Hank
1helpful
Video Card Upgrade Id like to know if the nvidia 9500 video cards are compatible with the Abit KN9 SLI boards. I currently have the 7800 GT style video cards. So I am a couple of years behind the curve. I...
I would not bother with the 9500 series they are just OC verisons of the previous ones, and everything above the 9500 (9600, 9700, 9800 et al) are too close in price to the latest generation, not cost effective. Take a look at this link, I believe it will satisfy your needs.
http://www.ewiz.com/detail.php?p=MSI-250_51&c=pw
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Can not save to bios
windows and the bios needs to know that the operating system can be shut down through windows, so when you go into the F2 or Del on boot up, go into advanced cmos setings and look for ACPI and make sure it is enabled. This sets the motherboard to support shutdown. Save and exit settings and reboot. Now go to control panel>performance and maintanance>power options and set the correct instruction for shutdown to shut the pc down. Remember evertime you remove the cmos battery or reset with jumpers you have to reset date and time and anything else you have changed to suit your set up
Top Abit Computers & Internet Experts
ExpressFiX
ExpressFiX
JTR44
Level 1 Expert
Grand Canyon Tech
Grand Canyon Tech
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
