Cyberhome DVR 1600 DVD Recorder Logo
Posted on Feb 09, 2008
Cyberhome dvr 1600 dvd recorder
Will not play region 1 dvd
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
502
Points
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
1 Related Answer
arthurroger
Arthur Aldrich
  • 170 Answers
  • Posted on Dec 03, 2008
SOURCE: Cyberhome DVR 1600 DVD
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
2answers
How can I get the diagram for dvr 1600?
You can download a manual from manuals online at the following address
http://tv.manualsonline.com/manuals/mfg/cyberhome_entertainment/1600.html?p=1
2answers
CyberHome DVD 1600 won't record to Sony disk
I believe the recorder is bad, it should be able to accept all brands and types of disks. You might want to try another brand and type of disk just to make sure, if it does not work, the recorder is bad. Good luck to you!
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
2answers
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Need 3 digit remote code for Cyberhome DVR 1600 PLEASE HELP!!!
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
  10. Exit the menu
CH-DVR 1600 ZU
  3. Press the Red Record button on your remote control
  4. Press the 8 button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 0 button on your remote control
  7. Press the 5 button on your remote control
  8. Press the Red Record button on your remote control
  10. Press the Setup button on your remote control
2helpful
2answers
CyberHome Manual
I just downloaded the manual yesterday from http://cms-system.cyberhome-dvd-help.com/modules.php?name=Downloads&d_op=viewdownload&cid=39. All I had to do was type "cyberhome dvr 1600 manual" into Google and it was the first result that popped up. Looks like they have other manuals available for download as well.
Cyberhome 1200
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
3answers
open the cover of dvr, clean the tray or replace the belt
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
