Anonymous Posted on Jan 13, 2010
Hooked it up but sound is very low. Has a ground
I have a JC Penney MCS series turntable I hooked it up but sound is very low. Has a ground screw on back ,what needs to go to it and where . I have it hooked up to the tape input as there is no phono port on my receiver. I also tried the aux port but the same outcome. I am thinking it has to do with the ground screw, but I see no ground screw on receiver to hook it to.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Dec 20, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
7082
Points
14
Output of cartridge is less than line level output. Pre amp that turntable. Your amp sounds like it was made after everything went line level.
Ground keeps low level static electricity down. TT outputs are unbalanced so the Amp and TT are grouned to each other anyway.
daniel
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 19, 2010
 daniel
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1386
Points
5
You nee phono preamps....price starting about 25 to thousand dollars...
then you can hook the preamps to the line in of your amplifier or receiver..(auxiliary, tape in, cd)
signal from turntable is different from tapedeck..turntable signal is weaker. it need preamps to match the line in of the receiver.
suggestion: get an old amplifier or receiver with phono input...these old original made in japan or usa etc sound great!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
380
Points
0
Didi you try to change the middle. that was what was wrong with mine
JC Penney model 7015AI Overlock Serger sewing machine. I need a power cord for it please.
Question edited for clarity.
They make it with a strange plug that goes into the foot pedal. It looks like you have to buy it complete.
https://www.google.com/search?q=power+cord+for+a+JC+Penney+overlock+serger+sewing+machine+model+7015A
This is a better targeted search query, but still points to Amazon
https://www.google.com/search?q=%22JC+Penney+7015A%22+sewing+machine+power+cord
or here
https://millardsewing.com/product/419451-003/
I have a used JC Penney baby bed model 343 778 and need the hardware and instructions for putting it together. Have some hardware but not sure that it fits this bed. P Brass, Iowa
Not one of these? Models have 4 numbers not 3?
JCPenney cribs recalled due to strangulation, suffocation ...
www.clickondetroit.com > consumer > 2013/03/27 > jc...
Mar 27, 2013 - JCPenney cribs recalled due to strangulation, suffocation danger. Drop side ... of the crib. The recall affects 14 models of the PT Domusindo Perdana wooden drop-side cribs. ... 343-1509 Jenny Lind Crib 01/1991-12/1997151.
Some JC Penney bed instructions that may help you, but not the exact one. Hardware can be purchased at Home Depot in the hardware, nuts and bolts section.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk02ECNPAzW_MGByxdkvKv96OnBmsTw%3A1609183090651&ei=ci_qX8-MJ8OutQbUyaGwAw&q=JC+Penney+baby+bed+model+343+778+instructions
Dec 28, 2020 • Baby Gear
I want to pay my JC penney bill on line.
You need to contact JC Penney directly or work through your bank.
JC Penney ultra sewing machine 5102 free arm
go google and type in---operators manual for jc penney eltra sewing machine model no (not given) and if there is one it will appear as a pdf version down load on a site
Lost remote for jc penney sterio mod#683-1938 am/fm/cassete/turntable/surround. need code to turn it on. if turned off by remote in standby mode and on/off switch will not over-ride. Intgrated into circuit...
Is this a "MCS" system from the "70's"? They stopped support in the mid "80's" I think, so all
you have for choices is a universal remote which
I doubt has a list of codes for MCS! May be another problem not letting it turn on.
2helpful
Need assembly instructions for JC Penney ''melanie'' crib
I have the assembly instructions for this crib. Maybe I can scan it and e-mail it, or just copy and mail it to you. Send me an e-mail at
s i n g h v i n @ y a h o o . c o m
Feb 07, 2009 • Baby Gear
11helpful
2answers
Need screws for cottage crib by rockland
1-800-933-7115
This is the number for replacement parts for furniture at jcpenney. i ordered new harware for my caden convertible crib
Very low sound from old turntable
You need to run that black wire to ground, perhaps a screw on your electrical outlet. You also need a pre-amp with your turntable, I use the mcm 40-630 you can find it many places for sale.
 Grubhead
Grubhead
SmartAviator
SmartAviator
