"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Depends on the make and model but an Error code E02 on most washing machines is slow water flow probably caused by a blocked filter! Remove panel on front bottom left or right side and clean filter! Should then clear error itself!
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code, To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
When you start your machine is the water just go stop go stop, Just wait for the machine to display an error code on the wash progress lights and beeps constantly. It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch. Your error code will determine this. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
Red spin light = 1
2nd rinse light =2
1st rinse light =4
last wash light=8
4th wash light=16
3rd wash light=32
2nd wash light=64
1st wash light=128
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
what light is flashing when it beeps. You might have to check and see if you are getting water to both Hot and Cold on the machine. Or your door might be closed all the way
