I want to know how to check the toner level of Brother DCP-7040
It has no accurate measure of the toner left, it is reset when you put in a fresh toner and just counts prints. The Brother shines a light thru a little window from right to left and when the toner is empty the light shines thru and it says it's empty.
Testimonial: "Right to the point. Thank you."
It's an internal counter, but if you press menu or reports button and scroll down to user settings and print that report it will tell you how many prints you have made and the life of the developer drum. It averages the toner usage based on the amount of toner for each print at about 25% coverage for each print.
Respectfully, I disagree with this answer.
I have a DCP 7040 and if you go into the menu, and find the "user settings" choice, and then print, it will give a half page report detailing the main menu setting choices, total pages printed, total pages copied and available ram. Below that will appear two bar graphs which show both the drum life and toner life and the percentages remaining. Hope this helps!
David.
Thanks for your reply.. but have one question. You said it counts prints. Is this an internal count or can I see the number of prints somewhere?
A note: I also have a Canon printer. That one does show the amount of ink in the cartridge so I was use to that.
komguy,
you really know your stuff and I thank you for the time you took in answering my query.
