However reliable and durable your Juicer is, at one point in time it
will need Replacement of parts. It is Great to buy a model from an
established brand like Breville, where Juicer parts or
accessories for these juicer machines are easily available.
hmm, i cant tell if this is the same as my juice fountain. mine just twists to the side and then you can lift both pieces out together. then the filter just falls out when i turn it upside down.
The coupling on the juicer basket end is no big problem, but the coupling on the motor end is a big problem as you need to stop the motor from rotating to unscrew the coupling. This means remiving the base of the juicer which may be difficult because of the type of screws involved.
JE90/06DRIVE COUPLING,
JE95/26FILTER BASKET & DRIVE COUPLING
If you email me at [email protected] I can help you with prices etc.
I have access to the Owners Manual for the JE90J if you email me at [email protected] I'll email you a copy. It's a PDF of a photocopy so it's not brilliant.
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
