What is password of dvr ge security problem: - GE Security DVMRe-16CT-600 16-CHANNEL Color Triplex Multiplexer-Recorder with 600-GB Hard Drive, Ethernet
Step 1 : Identify the DVR. • Launch the Alien-DVR-Reset-Tool.exe from the USB stick. The USB stick must be present initially but may be removed once. ...
Step 2 : Obtain a Reset Code. Ring System Q on 01246 200 000 and quote the. • DVR's serial number. ...
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all. CCTV Networking Technical Support
Turn the device Off
Wait 2 minutes
POWER,
HOME
VOLUME UP
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Press:
Freeze
View
Return
Reboot the DVR
UP, RIGHT, 5, 3, 3
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below. CCTV Networking Technical Support
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default. Samsung Security DVR Reset Procedure #1
Turn the device Off
Wait 2 minutes
POWER,
HOME
VOLUME UP
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Press:
Freeze
View
Return
These reset procedures cover many Samsung Security DVRs, but not all. I will add reset procedures to this article as they become available to me. By design, Security DVRs are made to be secure, and not all of them can be reset by the consumer. If you have an urgent need related to your Samsung Security DVR, you should contact Samsung directly at their support page Samsung Support, or by calling: 877-349-3149. For less urgent matters, you can email them directly at Email Samsung Support. Support is available 7 days a week, 9:00 am - 9:00 pm EST.
The TVR 30 is shipped with one predefined user for the system administrator and
seven predefined standard users. The default system administrator logon uses admin
as the account name with a default password of 1234. You can modify the admin
password but not the admin user name. The seven predefined standard users are
labeled User1 to User7 with a default password of 4321 and level 4 access. The
administrator can customize the seven standard users and define their privileges.
Use the Users screen (shown in Figure 20 below) to manage users.
Note: When accessing the main menu for the first time, the system lets you pick
either an admin user or a regular user (User 4) by default. If you select User 4, enter
the initial default password of 4321.
If memory serves me correct, most of the GE/Truvision etc. DVRs have to be sent back in for the password to be defaulted. I may be incorrect on this, will double check.
