Computers & Internet Logo
Posted on Jan 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can´t install drivers for modem on board in my dell laptop and I need to do it
Anonymous
Level 2:
  • Expert 297 Answers
  • Posted on Jan 13, 2010
Anonymous
Expert
Level 2:
Answers
297
Questions
0
Helped
184153
Points
949
Click to the link & doe=wnload the drivers which you want
http://www.nodevice.com/
hopr it helps
I have a reconditionned DELL Precision M3400 laptop that was factory reset when I bought it. I have had to turn on all the hard drives etc. but I am having trouble getting the internal modem to turn on. It...
Usually the recondition, or refurbished product from Dell have been retested to ensure they meet all original factory specifications. I don't understand why your modem and cd rom drive don't work. How long had you purchased it? When you said you can't get internal modem to turn on, you meant it not working?
There are only two things could happen to each of them (modem and cd rom drive) For Modem: please check it through device manager, and modem to see if it has red x or yellow question mark, or says unknown device, if you do have one of these, you need to install correct driver. Please check your Dell service tag number (it is on white sticker on back of laptop), and go to dell.com, support, and select driver and downloads, key in your service tag number, and download the modem driver to install. If it still doesn't work, then the physical internal modem is the faulty one. For your CD rom drive, it should work with just standard driver preloaded by the OS, you don't need to install driver for. It is either dirty, needs to be cleaned by the CD room cleaner disc, or it is bad. You can try to reseat by trying to take whole thing out and insert it back in. If you have Dell diagnostic cd (usually comes with your laptop when ordered) to run hardware diagnostic to find out the faulty one.
This is the common issue with refurbished laptops (most common issue is with keyboard). When buying refurbished one, you have more chances to have some part issues. I suggest to reinstall modem driver to see if it works, and try to clean cd rom driver and reseat it, and hope for the best. Let me know the status Thanks
Modem Device on High Definition Audio Bus!! dell d620 in my laptop dsl is not working it disconnected again n again why please help me
Maybe it's an driver installation order problem, the system needs the audio drivers installed prior to the modem since I believe they are both on the High Definition Bus. Here is Dell's official install order for the D620 with integrated Intel graphics...
1. Install the Dell Notebook System Software on a Dell Portable system from the Drivers, Utilities and Applications CD.
2. Install the Intel® Mobile Chipset Driver.
3. Install the SigmaTel STAC92xx Audio Driver.
4. Install the Alps GlidePoint/StickPointer Driver on Your Dell Portable System
5. Install the Conexant D110 MDC 1.5 v.92 modem driver.
6. Install the Intel® 945GM/945PM video driver in Microsft® Windows® operating systems.
7. Install the Broadcom 57xx Gigabit Integrated Controller Driver
8. Install the Dell™ Wireless 350 Bluetooth® driver in Microsoft® Windows® operating systems.
9. Install the wireless network adapter in a Latitude D-series portable computer.
10. Install the O2Micro OZ601 Cardbus Controller in Microsoft® Windows® operating systems.
Dell Latitude D620
Bios A02
Core Duo T2600 @ 2.16ghz
2048 MB DDR2 667mhz
NVidia Quadro NVS 110M TurboCache
100gb 5400rpm HD
Philips SDVD8820 DVD+/-RW Combo
SigmaTel C-Major HD Audio
Broadcom NetXtreme 57xx Gigabit
Intel Pro/Wireless 3945ABG 802.11a/b/g
TrueMobile 350 Bluetooth
Windows XP SP2
Hi there, i have a dell latitude d620 refurbished and there is no sound when watching video clips via youtube, mediaplayer etc when i go to control panel is says no audio device. is it jst a driver update...
yes, if there's no audio device you'll have to install the drivers. Check also if you have a modem installed. In some laptop models the sound and modem were hooked onto a UAA bus, which requires a Microsoft UAA driver (about 70MB file). I've seen one too many times that peoplw who reinstalled Windows forget about this driver and then cant install the modem and sound card.
My computer crashed, I put in the Dell disk and it is now up and running but the modem is not working. How can I fix it?
Hi
You just need to install the Network Driver for you modem or sometimes you will have a driver for your modem.You can find the modem/Network driver either in the Dell Cd or in the other CD you got along with you laptop. If you dont have the driver in both just check the manufacturer of the modem so that you can get the driver of the same from the manufacturer's website
Thanks
1helpful
2answers
Laptop won't recognize dial up modem. I'm not sure if the small internal modem is all I need for dial up access, or if I need to get a PCMIA card. It's a Dell Insprion 2650 laptop. Thanks
If the internal modem is functional and the driver is installed, then that should be all you need for a dial up connection. If the modem is listed in device manager without a Yellow Exclamation Point then the driver is likely loaded properly. if it does have an exclamation point, then you may need to load the driver. There were 3 different modem models shipped with that system.
Actiontec MD56ORD PCTEL Connexant D480
drivers are here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=INS_PNT_P4N_2650&os=WW1&osl=en&catid=&impid=
If installing drivers doesn't resolve, then a PCMCIA modem is a inexpensive option
3helpful
2answers
New, second modem won't recognize modem
You probably need to install network adapter driver on your new hard drive.
Go to my computer properties, select "Device Manager" and see if there is a network adapter installed and working.
I can´t use my web cam, It says that it´s not installed. what do I have to do? My lap top it´s a dell inspiron 1525.
Go to control panel and uninstall programs, on there if you see a driver for the web cam then uninstall it.Then restart pc and plug in the camera and it will ask you if you want to install the driver software and click yes for it and allow re-installation.This should solve your problem.
23helpful
Modem device on high definition audio bus download
go to support.dell.com, choose drivers and downloads, then type in the service tag of your dell laptop. you can find that number on a sticker at the bottom of your laptop. then you will have all the drivers for your laptop. download and install the modem driver.
Modem not working
Here is the url for dell drivers:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
I don't think you would be using modem for internet connectoion.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
