Vizio VW32L 32 in. LCD HDTV Logo
Posted on Jan 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio 42 inch remote is dead. Except volume up /
Vizio 42 inch remote is dead. Except volume up / down and Mute. Changed batteries twice. Still dead. I have to get up to turn it on and off and change channels on the TV. Any way to fix this?
"Ezeduzit"
[email protected]
Chi Chu
Level 3:
  • Vizio Master 8,457 Answers
  • Posted on Jan 13, 2010
Chi Chu
Vizio Master
Level 3:
Answers
8457
Questions
0
Helped
2822913
Points
26282
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
I have a 42 inch Vizio tv, 7 years old. The menu button will not work although other buttons, like volume button does. Why would menu button not work?
I have a similar issue with my 10 year Vizio 42", it is the infrared receiver in the TV that is the problem (tried other remotes).
Tv turns on but has no picture or volume
remote has nothing to do with it you need to replace your power supply and mainboard buy [email protected]
7helpful
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
25helpful
4answers
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
2helpful
2answers
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
146helpful
13answers
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
57helpful
13answers
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
6helpful
2answers
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
