GE GSL25JFPBS Side by Side Refrigerator Logo
Posted on Sep 12, 2017
Warped the Dispenser and Housing Shield Thawing the Waterline
I used a hairdryer to thaw the waterline on my GE GSL25JFTABS refrigerator and the plastic melted and warped. Because of this I've had to purchase a new funnel ice dispenser. A spring (funnel spring) fell off before I could see where it went and I can't locate where it went. I don't see any guides online to show where the spring goes on the funnel. Any suggestions?
5 Related Answers
Anonymous
  • 237 Answers
  • Posted on Jan 08, 2007
SOURCE: GE side by side refrigerator ice dispenser
If you take a look at this diagram, you should be able to see all the inner workings of that area and decide if you want to repair it. I think anyone with the most basic mechanical skills could easily handle this repair. See parts 62,63,67, etc. Could just be the spring is off or broken. Let us know what you find! http://www.partselect.com/Schematics/GE/00112435i01.gif
A
Anonymous
  • Posted on Sep 11, 2008
SOURCE: GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Anonymous
  • 3 Answers
  • Posted on May 17, 2009
SOURCE: I hooked up my refrigerator and my ice maker to
i had the same problem one time and there was something obstructing the fan under my frig and i blew thru it to icemaker with compressed air and it started working
Anonymous
  • 1606 Answers
  • Posted on Aug 28, 2009
SOURCE: I have a GE refrigerator whose white funnel
Just pop the old one out , and snap the new one in place .
Anonymous
  • 534 Answers
  • Posted on Oct 06, 2009
SOURCE: frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
1helpful
Where can I find a waterline for my GE glm23qeta gRefrigerator
Take a piece of your current water line to the local appliance store. They will probably have what you need.
2answers
Water dispenser in door does not dispense
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
http://www.amazon.com/LG-Electronics-MJX41178908-Refrigerator-Water/dp/B00AUDAJ0I
GE Mongram Model# ZISS420DRJSS replacing ice despenser flap
You are correct, The door panel would need to be removed to access the dispenser. Be-careful of the ground wire and the waterline that is/will be exposed when you removed the panel. they are easily damaged if your in a rush when removing the panel. Remove all screws, start removing panel on hinge side first (thats where the waterline and ground wire is) then it will come off easy. Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Ge gsl25jfta bs
http://www.appliancepartspros.com/repair-help/general-electric-refrigerator-gsl25jftabs-repair/gsl25jftabs-frost-buildup.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 24, 2017 • GE Freezers
Water dispenser in GE side by side continues to freeze. Temp is set at 4 (of 10) I thaw the line and a day or so later it freezes again...
Install pt # WR49X10173 from GE . This is a waterline heater , to stop this problem . It comes with instructions and is easily replaceable .
1helpful
Ice maker waterline frozen
Occasionally these freeze up on many brands. Usually if the ice maker is not used much. There is a rubber tube that deposits water into the ice maker unit, Thaw it by warming it with your fingers. You can carefully use a hair dryer as well
The part of the waterline that feeds into the ice
Thawed the freezer and then inserted the tube back into the water supply hose.
Waterline keeps freezing
clean the bottom of the refrigerator. sometimes coils need to breath and if doesn't breath everything will get frozen or thaw out
Ice maker and water dispensor not working on GE profile model 26...could it just be a frozen line?
yes.........unless the waterline from the house hookup ie--saddlevalve is plugged follow the waterline from where it hooksup turn to close all the way!!! then turn it back on see what that does for you because if the saddlevalve is hooked on the bottom of the waterline it could have gotten plugged over time
10helpful
Water dispenser doesn't work on ge hotpoint freezer
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
Top Refrigerators Experts
vince
Johnny 1000
