Panasonic DMR-E50 DVD Recorder Logo
Posted on Dec 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DMR-E50 DVD recorder versus DMR-ES15 are these equivalent recorders
Hello I have a DMR-E50, that has been repaired 6 times due to recording fault. The store are finally going to replace it with a Panasonic DMR-ES15.
My question is this, is this unit an equivalent unit.  I currently have a Harmon Kardon Receiver AVR 135, Loewe TV 100 Mhz and Sansui digital receiver.
Demonic-2011
Level 3:
  • Panasonic Master 513 Answers
  • Posted on Dec 22, 2017
Demonic-2011
Panasonic Master
Level 3:
Answers
513
Questions
0
Helped
211988
Points
1606
The DMR-ES15 is a later model (around 2006/07) than the DMR-E50 (2003/04), but essentially both should do the same job so technically - a good equivalent in terms of recording and same brand so yes. The connections on the rear (of the replacement recorder) should suit and work with your other devices just as the old one did.
According to some other online reviews, the DMR-E50 has had a few issues with recording, and finalizing certain discs.
I'd say go for it - accept the replacement - as long as it comes with some kind of guarantee, works fully and has all the accessories (including remote, instructions etc.) you should be good. Contact the store and seal the deal.
I hope you can get this in time for Christmas.
4 Related Answers
Anonymous
  • 3 Answers
  • Posted on Aug 24, 2008
SOURCE: tuning tv stations for panasonic dvd recorder DMR ES15
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
Anonymous
  • Posted on Oct 22, 2008
SOURCE: panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Jenn Ellis
  • 17 Answers
  • Posted on Sep 09, 2009
SOURCE: Problem with Panasonic DVD Recorder DMR-ES15
With a soft cloth, clean the 'hole' area of a DVD that you know worked in the past. Sometimes oils from our fingers get on the disc and then the disk can't spin properly. If the problem persists, open the case and look for two failed capacitors. (See similar solutions on this website.)
Anonymous
  • Posted on Apr 18, 2010
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Can't play recorded DVD-R on DMR-ES15. Keeps saying disc incompatible. Why?
the recorded program might not compatible video format of your dvd player, tried to convert in other video format.
Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
Dmr-es15
My DMR-ES15, dvd recorder is showing a U-61 code, I'd done all the instructions on my user manual. I think the problem is lost of memory. How can I get it back working. If I have to change chip of memory what is the part No., and how much will cost me in US dollars. Thanking you in advance.
Panasonic dmr es15 dvd recorder
DMR-E50 DVD RECORDER
Hi
That's very strange, I have not seen a Panasonic do that before.
There are two things I would try.
1) Remove the batteries from the remote controller. This will rule out the possibility of the buttons making contact due to moisture or a fault in the controller. Then see if the problem occurs.
2) Unplug the power cable from the DVD recorder and leave it disconnected for at least 30 minutes before reconnecting it. This will reset your machine in case something has been corrupted.
3) When you have reconnected it, check the programme settings to make sure they are all clear.
4) Your machine could be picking up some radio interference if there is a transmitter close by. This is an unlikely cause, but if you suspect it, try plugging your machine into a different power socket and re-route the connection cables.
This particular model, like numerous Panasonics, suffers with an overheating regulator on the power board. They almost all fail from about two years onwards. The regulator gets very hot during normal operation and is not adequately protected from thermal runnaway. Regulator faults can cause a number of problems such as continuous self checking, switching off, and not reading certain discs. I have not known the regulator to cause unprovoked recording, but there can always be a first time. If the regulator is causing problems, the unit is easy for an engineer to repair. I can provide information on how to repair faulty Panasonic regulators if you need it.
Best wishes
2answers
No read
The DVD-RAM Disk had trouble afeter Multiple recordings or any scratches. Buy a new DVD-RAM Disk and Try using that.
4helpful
Panasonic dmr-es15
Pan. DMR-ES15 I WILL NOT RECOGNIZE ANY DISC I PUT IN. WILL NOT PLAY A COMMERCIAL DVD MOVIE. SEEMS TO HAVE STARTED WHEN IT COULDN'T FINALIZE A RECORDED DISC. HOW TO RESET?
2answers
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
