RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Every time i turn on my blackberry 8320 it says battery drained.
Blackberry 8320 i turn it on and says battery drained,shutting down handheld. please help me i need my phone and i already tried it with some body else's battery so its not the battery please help.
  • Anonymous Mar 17, 2014
    bb 8320 doesn't charge says battery drained out handheld shutdown
Anonymous
Level 3:
  • Master 492 Answers
  • Posted on Jan 12, 2010
Anonymous
Master
Level 3:
Answers
492
Questions
0
Helped
129015
Points
1243
It is the main board. If you have phone insurance through your carrier they should be able to replace it. Otherwise there is not much you can do aside from purchase of a new phone.
Where to download os for blackberry curve 8320
blackberrysync.com > BlackBerry
thepiratebay.org/.../BlackBerry_Curve_8320_OS_4.5.0.102
www.blackberrycool.com/.../os-45-rogers-blackberry-curve-83108320-blackberry-bytes/
  • Download BlackBerry Curve 8320 OS 4.5.0.124 Torrent ... 27 Jan 2009 ... Download BlackBerry Curve 8320 OS 4.5.0.124 torrent or any other torrent from Handheld category. Direct download via HTTP available as well.
    www.kickasstorrents.com > Applications > Other Applications
  • blackberryrocks.com/.../official-os-450124-8300-8310-8320-indosat/ try these links to see if this is what you are looking for..
    Jun 12, 2011 • Cell Phones
    3answers
    Blackberry 8320 keeps resetting - get "your handheld has been registered... message"
    HI,
    In your initial sync window in Desktop Manager, UNcheck the box that states something like "Update time and date on sync"
    I have a blackberry curve 8320 battery is fully charged and it wont turn on _ i tried another battery and it still wont turn on
    I would like to suggest you to visit the outlet from where you have purchased the handheld to service the handheld.
    Hope I have helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    When turning on my blackberry pearl 8120 all i
    We suggest you to reinstall the software and check the handheld. If you face the same problem even after reinstalling the software, you need to visit the outlet where you have purchased the handheld to service the handheld
    Display message Battery drained.
    might be the battery falt or the battery power recognization ic is worn out
    1helpful
    8320 shuts down in the middle of calls or rather does a restart as if you press alt shift delete keys. Only happens when talking on the phone. Happened maybe once a month for the first few months and...
    Once the BB 8320 shuts down in the middle of calls, more likely it's the battery. There were times that you would see that the battery is fully charged, but once the call comes in, the battery is starting to discharge quickly and unexpectedly.
    And after it dies, it would try to re-gain a small amount of power. But you need to isolate the problem, try using different battery to test it. Some repair shops let customers use their spare batteries for testing purposes.
    Or contact Blackberry manufacturer for second opinion.
    Have a great day!
    2answers
    My BB 8320 will not power up
    try turning it on with the battery removed while it is connected to the charger.
    if it turns on fine then, it's a battery issue. if it still doesn't come on, i would recommend reinstalling the device software with the desktop manager software. both are available on blackberry.com
    1helpful
    Blackberry curve 8320 wont charge? Keep sayin battery drained, shutting down handheld
    Have you tried different chargers?
    It's either the voltage regulator in your curve or a very weak almost dead battery.
    You can test the batt if you have a friend with a curve, swap batteries in your phones and if yours works again and his does what yours did, get a new battery and all is well. If yours keeps acting up with the swapped battery, it may be time to get a new phone.
    1helpful
    2answers
    My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. The icon stays on with the backlight until the battery dies, A new battery was tried and problem...
    This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
    1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
    2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
    3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
    4. Take in.
    8helpful
    2answers
    My Blackberry Curve 8320 does NOT have Blackberry Messenger
    If you want to install Blackberry Messenger on handheld do the following steps :
    1. Download the latest BlackBerry Device Software from your service provider's web site.
    2. Install the BlackBerry Device Software onto a computer that has BlackBerry Desktop Manager installed on it.
    3. Connect your BlackBerry device to the computer.
    4. From BlackBerry Desktop Manager, double-click Application Loader and follow the instructions in the Application Loader Wizard to install the BlackBerry Messenger application.
    Top RIM Cell Phones Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Kolbrun...
    k24674
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
