iLO DVDR05 DVD Recorder Logo
Lela Glaze Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is the DVDR05 compatible with the new flat screen LCD TVs that is hooked up to an antenna?
Anonymous
Level 3:
  • Master 492 Answers
  • Posted on Jan 12, 2010
Anonymous
Master
Level 3:
Answers
492
Questions
0
Helped
129017
Points
1243
As long as you have some way to output from the tv to the recorder it is compatibile. If not, you will need the digital box for the antenna
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
160
Points
Is therea certain dice
  • Anonymous Apr 03, 2011
    recording blank ?
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
1helpful
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
I have a Sony KDL-V32XBR1. The turner seems to be having issues. If I scan for channels I only find a few but my other flat panel receives a full range of channel.
U are using a antenna to do a recieving for a Free AIR DTV incomming braoadcasting tv signal channels siganal?Yes.U are using two different tv antennas signals wright?The Sony one just require a stronger and a better antenna signal,not all flat LCD or Plama tvs recieve the same strenghth signals.Some tvs design require a strong or a very strong signals strenght to get all the tv Free AIR DTV braoadcasting tv channels.Buy a better tv antenna design like a Digital amtenna will solved this problems for the Sony tv.
How do I connect an analog antenna to a 32 inch sharp aquos tv? and do I need a specific input setting?
antennas are not analog or digital, just VHF, UHF and they typically connect to a RF coaxial jack on the TVs rear panel. 75ohm silver round jack. Select in your TVs menus, AIR when you want over-the-air TV stations and do a new channel scan to pick up local channels.
1helpful
Cracked screen how much to fix an lg 42in flat screen tv
Sorry,tv now it is not worth fixing,because the tv LCD screen panel are 90% important to the tv and it is in limited production by the tvs corporations,by replacing the tv LCD screen panel will cost the same as a new tv.Sorry tvs with a broken or damages LCD screen panels are tvs only can be used as salvages tvs only for it electronic boards for other tvs only now.
I'm wanting to know if this TV is one that is Digital or analog? Will I need to buy a converter box for it if it isn't hooked up to cable or direct TV? I believe it was purchased in 2006.
No.It is a digital tv.Just require a good digital antenna for a better and a longer ranges for the tvs broadcasting stations incommming signals.After a digital antenna is hook up.When u go in to the tv menu go to Setup.go down to CH. pick AIR and enter and tv should be automatically be scanning for DTV free air broadcasting tvs stations.
I have an LG47LG70 tv which has recently started flashing the screen on and off when hooked up to the local antenna. It works fine when hooked up to the Dish Network cable. I have replaced the antenna...
Tries hook up to a roof antenna or a better antenna like a digital antenna.Than rescan ur tv again,for those DTV free air channels again.Ur tv now,should get all those DTV free air channels.
I inherited a Sharp LCD 32" flat screen TV that's only about 2.5 years old. It worked fine at its previous location. Upon bringing it to my house, I've tried disconnecting the cable from my TV &...
Try going into your setup menu. Look for a setting for "Cable/Air". Try switching it to Cable and then doing a channel search. If you are using a cable box try setting channel to 3 on tv. Those are the two easiest things I can think of off the top of my head without seeing it.
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
