HTC Hero Smartphone Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i add downloaded ringtones to the menu so that i can select them when setting the ring tone for an individual. right now the menu only gives me the canned ringt ones
Roy Limpawuchara
Level 3:
Guru:
  • Master 352 Answers
  • Posted on Jan 15, 2010
Roy Limpawuchara
Master
Level 3:
Guru:
Answers
352
Questions
Helped
131231
Points
1172
You will need to access your phone as an external storage device and save your ringtones onto the SD card.
Plug your phone into your computer with the USB cable. On your phone, pull the notification screen down and select USB connected. Select "Mount". Your computer will now recognize your phone.
Go to your SD card and you will need to create a directory titled Media. Inside this directory, create another directory title Audio. Within this directory, create one final directory titled Ringtones.
Place any supported sound files in that final directory and they will appear in your ringtones list.
You can also create an Alarms directory, and use any supported sound files as alarms for your phone.
Remember to pull the notification screen to turn off the usb storage.
Hope this helps, and good luck.
2answers
The User Manual does not explain how to change the ring tone, can you help please?
Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
1helpful
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
3answers
How do I download a ringtone from my pc to my iphone 4
go to myxer.com and find a song you want then there should be a button that says download for iphone. You will then download the file. Once downloaded you click and drag that file onto iTunes on the top left where is says music, movies, ect. it will then make a ring tone category you can now sync you phone and the ring tone should me there :)
2answers
I bluetoothed ring tones to my new phone. it automatically placed them in the music player. i cant figure out how to assign them to caller custom ringtones
Goto your address book, click on the contact you wish to add a custom ringtone to. Press the menu key to select "edit contact." Once you are in the edit mode, click the menu button again and select "add custom ringtone. You can click the present ringtone to bring up the browse slection. From there you can find your bluetoothed ringtone.
Hope this helps,
Bill
2answers
How do i assign individual ringtones to my lg km380 cellphone
Follow the path: (1) Menu_Contacts search for the contact you want to assign a ringtone. Select "Options", you will get a Menu containing option "Edit". Select it and you can add or edit a ringtone to the specific contact.
(2)You probably wont get option to assign ringtones, if the contact is saved to your sim. So first u got to transfer the contact to you phone memory. This is how. Just go to Menu_Contact and search for the contact and press edit, you will get a option "Copy to phone". Select it and copy it to the phone memory. Once copied you can edit the ringtones by following the steps as in (1)
25helpful
4answers
Change ringtone on cect i9
1. At the main menu, select “Settings”
2. Now select “User profiles”
3. In the next menu, select “General”
4. Now “Customize”
5. Select “Tone setup”
6. Choose which SIM (on dual SIM card phones) you want to assign a ringtone to.
7. You will now see a list of available ringtone.
8. Select it.
You should see at the very bottom of this list 5 empty locations this is where you can add your own mp3's as ringtones.
Now I Know your second question once you get this figured out will be how to assign ringtones to individual contacts in your phone book so here is part 2. 1. From the Main menu choose Phone
2. Choose Quick search
3. Find the contact in the list you want to add the ringtone by scrolling down the list and tap on their name
4. Choose Edit
5. Scroll down the list of options to the Musical note called Associate sound and select the ringtone from the list.
Your new ringtone will now function for that contact whenever they call!
13helpful
4answers
Setting personal music as ringtone
open your music files select your music to be used as ring tone. hit menu. then use as ringtone
Dec 07, 2008 • HTC G1
6answers
Using a file in MY Rintone file as my call ringer
When Your Ring Tone Is Highlighted Click on it then click Menu And Select Set As Ringtone. That Will Now Be Your Defaullt Ringer.If You Want It To Be A Custom Ringtone i can't help you with that sorry.
Individual caller ringtone
1. go to contact list and edit contact then select assign tone and select tone according to ur choice, but take care of selected profile.
Change ring tones
TXgrl, To change your ringtone, try the following: 1. Press Menu 2. Goto and select settings 3. Goto and select ring styles 4. Goto and select style detail From there you should be able to find the ringtone option and you would select that to see other ringtones to select from. Also, your phone does have capabilities of having individual ringtones for different callers, but the contact has to be saved to the phone and not the sim. To change the contact from sim to phone, try this: 1. Goto Menu 2. Goto and select Phonebook 3. Goto the contact you want to save to the phone and press menu 4. Goto and select edit 5. In edit, there should be a option saying, "Stored", if it's saved to the sim, it will say sim, select edit or press left/right and it will change it from sim to phone. 6. When saved to phone, some options should appear. One of them is ringer id. 7. Select edit on ringer id and that's where you'd select the ringtone to use for that contact. If you have any questions, please feel free to contact me. Let me know how it works out. thanks. John
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
