the HONDA Horizon (Isuzu wonder box)
what engine. exactly .?
3.2 L
6VD1 SOHC V6
3.2 L
6VD1 DOHC V6
3.5 L
6VE1 DOHC V6
3.0 L 4JX1
TD I4
3.1 L 4JG2 TD I4
x1 or G2?
floods, wot cranking cuts fuel and starts any flooded engine,
it's overheating that wins the First order failures rule sets.
nothing else matters. cure that first.! find cause! first.
sounds (im deaf there,lol) that smoke is out tail pipe end and dissipates fast and is not smoke but steam, , oil smoke smells like burning oil and lingers. steam smells sweet like burning Antifreeze.
AF steam is a blown head gasket or far worse.
do a compression test first to see if it's even worth fixing????
most are NOT. (unless free labor, sure)
first learn steam from smoke
serious , watch moms tea pot. see that steam goes away fast.and very uniquely , now watch burning oil.
remove dip stick, drop the drip of oil on hot exhaust manifold.
smell that, that is oil burning, and lingers.
this will last you a life time of blown engines..... just one look and bingo. (my instructor in 1965 did in front of class)
got oil in the AF/ CARBON chunks in same.
water in oil, ? pan, engine . milky oil.
rad leak down test fail? can be lots of reasons even a cracked block.or head. not just gaskets.
