The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10 1. Turn on the projector2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
