2 wires out of wall a black, white and ground. the new cook top has red, black, white and green tied together. wonder how to wire it with out running new wire.any ideas?
Try to use black to black: white to red: and green and white to ground.
you may not have a 240 volt supply to this unit. most of the time when you have these color wires that would tell me that it only has 120 volts of power.
you can try to wire it up as described, but it may not heat enough with just 120 volts.
what type of cook top did you replace, a gas unit and now your changing it to an electric one?
if so, then you will have to replace the wiring inside the wall with the proper size wiring to handle the extra current from an electric unit.
im replacing a jenn-air electric downdraft smooth top with a ge electric downdraft. also it's a 40 amp breaker with number 8 wire
your comments are helpful
