Question about Apple iPod touch
IPod Touch. No auto-reconnect feature for bluetooth?
I have a 32GB iPod Gen3 Touch. I like to bluetooth this to my car stereo but unlike my mobile which has an auto reconnect feature, I have to keep syncing the BT when I start the car which takes longer than nessasary in my opinion and is basically just a pain in the arse. Anyone know a way around this?
  • Marjor Jackson
    Marjor Jackson Feb 01, 2018
    Apple iMac is the flagship computer device. It is designed by Apple. Mac OS is more user-friendly and reliable. But sometimes users face some basic problem like Unable to install Mac OS X, Problem in syncing with iCloud, Unable to access iTunes. IF you are facing this types of problem then you contact us. imac customer service number
You can know more by checking this https://klantenservicenederland.co/outlook/
Posted on Jan 14, 2020
    New Friend:
To know more information about Arlo camera support:
https://www.247arlosupport.com/arlo-support/
Posted on Oct 08, 2018
    Habit-Forming:
    New Friend:
  • 62 Answers
On some cars you can set a priority. Check in your car menu what currently is the priority, if any, and enter your iPod as this after you pair It. Hope this helps.
Posted on Jan 16, 2018
Anonymous
SOURCE:
Ekse
  • 13434 Answers
SOURCE: Ipod Touch Sync Issue
Hello
Sorry I don't have much time to guide you right now
but start with this page here
http://support.apple.com/kb/HT1207
Posted on May 13, 2008
mneilsen2084
Mel Neilsen
  • 342 Answers
SOURCE: ipod nano gen3 (the square one)My daughter's ipod nano gen3 will all of a sudden not charge. Any thoughts?
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on Jun 02, 2009
Anonymous
  • 18 Answers
SOURCE: need to restore apple mobile device helper
youll need to reinstall itunes, and ipod software onto the computer. Then it should pick up your itouch and you can restore it.....if it doesnt work which it may, youll need to send it in to apple. I had an older ipod it showed up with apple support site, and i had to send it in to them!
Posted on Aug 14, 2009
Jim Thomson
  • 1099 Answers
SOURCE: My Apple Ipod Touch (8G) keeps repeating the same
On the track click on the screen at the top left under the timelinethere is a symbol of two arrows in a circle by touching the symbol you change whether a track is repeated or not
Posted on Oct 21, 2009
Testimonial: "Good advice. Had to really look for that symbol. I Know it was under the timeline, but still hard to see. Anyway, it worked and thanks."
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: INSTRUCTION MANUAL FOR 32GB TOUCH SCREEN MP3/MP4 VIDEO
Go to this website and download a pdf user manual for your Itouch. I hope this helped, Please rate me...Thanks
http://manuals.info.apple.com/en_US/iPod_touch_Features_Guide.pdf
Posted on Jan 03, 2010
Testimonial: "Very helpful. Thanks very much"
I am trying to help my husband with this problem. He just installed a Delphi CD/MP3/USB/iPOD/Aux/Bluetooth Receiver in his semi. He has paired his cell phone and it is being seen by the radio. We he...
You cant run 2 bluetooth devices over one mic. That is with exception to a cell phone that has a music player built in that has an auto mute function for incoming calls. Check the stereo for an auto/mute feature for inbound calls. If you see nothing in the manual for that feature then that stereo just doesnt allow it. If so it will show you how to turn it on. His other option is to buy a bluetooth ear mic just for his cell phone.
Mar 22, 2015 | Car Audio & Video
How do i unlock security code on my ipod 4
1. Launch the Safari Web browser on your iPod touch 32GB by tapping its icon on the home screen.
2. Navigate to the "JailbreakMe" website. A page displays with details of the Cydia application store.
3. Tap the "Free" button in the upper right corner of the page and then tap it again when the text changes to "Install." Cydia downloads to your iPod touch 32GB and the jailbreaking process begins.
4. Launch Cydia after installation has completed. Tap the "Complete Upgrade" button in the pop-up dialog box. The latest version of Cydia installs, and the iPod touch 32GB reboots to complete the jailbreaking process.
Jailbreaking an Apple device is a process that enables users of iOS devices, such as iPhones and iPods.
Aug 08, 2012 | Apple Ipod Touch 32gb 4th Gen Itouch 32 Gb...
Apple ipod touch 32gb wont turn volume up?
Here is a cool feature that will solve this problem: Just tap home twice. Doing a double tap on the home button brings up music controls no matter what you are doing, music, video, NES, Safari etc.
Feb 15, 2012 | Apple iPod Touch 8GB 32GB 64GB 3rd...
We have paired 8gb ipod touch with parrotv5.11c
Use this link or search google for a2dp.
" Try this search or search google aboit A
"http://www.ilounge.com/index.php/articles/comments/what-to-expect-stereo-bluetooth-iphone-3g-with-iphone-os-30/"
Jan 01, 2012 | Apple iPod touch
Does lg ku6300 has a wifi? if not, can i download application for this?
It does have wifi and you should use the app store in the phone
Key features
  • One-off touchscreen bar design
  • 4.01" 16M-color capacitive touchscreen of 21:9 aspect ratio
  • Quad-band GSM support and UMTS with HSDPA 7.2 Mbps
  • S-Class Touch UI with pinch zooming and gesture controls
  • Accelerometer for screen auto-rotation
  • 5-megapixel autofocus camera, Schneider-Kreuznach certified optics, LED flash, VGA@30fps video recording
  • 1.1GB of internal memory, microSD expansion (up to 32GB)
  • Wi-Fi with DLNA
  • GPS receiver with A-GPS support and WisePilot satnav app
  • Bluetooth v2.1 with A2DP, microUSB port, TV out
  • Standard 3.5mm audio jack, Dolby Mobile sound enhancement
  • Stereo FM radio with RDS, FM transmitter
  • Full-blown multi-tasking with a decent task manager
  • DivX/XviD video player
  • Motion-based games
  • Smart dialing
  • Office document viewer
Main disadvantages
  • Single-handed use not too comfortable due to the extra long form factor
  • Video recording output is pathetic
  • Piano black surface is a fingerprint nightmare
  • Memory card slot is under the battery cover
  • Web browser has no Flash support
  • No video streaming over Wi-Fi (such as the mobile YouTube)
  • WisePilot satnav app is only a trial version
  • No sign of any social networking integration
Mar 17, 2011 | LG Cell Phones
Hello: I have had my ipod touch for a long time now no problem until now.....i have ipod touch 3G 32gb and whenever i listen to music....and i put my headphones in the jack. If i move the ipod itself like...
smoething like that happened to me. do you wrap your headphones around the Ipod when you're not using it? The connections inside the headset can break if you do that, and if its not the headset, then it is likely that something in the general vincinity of the headphone jack is loose.
Feb 02, 2011 | Computers & Internet
I don't know how to use the Bluetooth on my iPod touch I want to send some songs to my cell
To turn on bluetooth on the iPod- settings>General>Bluetooth>On. iPod Touch will only detect AD2P Stereo Headsets, not mobile phones, none AD2P Stereo Headsets, and others. hope this will help. Enjoy !!! Thank you for using Fixya !!!
Nov 14, 2010 | Computers & Internet
I have a 32gb iPod Touch 3rd gen. I cannot
lol because your CAR cant be used for bluetooth speakers for bluetooth enabled music players.. your car CAN USE phones that are bluetooth and call people with your car..
Mar 02, 2010 | Apple iPod touch
My friend's iPod Touch 32GB is disabled & cant connect 2 iTunes. We're tryin 2 figure out how 2 reset it
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Warning: you will lose all your data
but it will definitely solve your problem.
Oct 02, 2009 | Apple iPod touch
Cant hear music through my LG HBS-200 Bluetooth Stereo Headset
I have the same problem with my HBS-250. It was working fine on my iPod Touch. It worked the first couple of weeks on my iPhone 4 then stopped playing music. Phone funtion works. No music or podcasts or streaming from the web
Sep 12, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
Apple iPod touch Logo
992 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
