For example, to search for a code for your TV:
NOTE: In the searchmode, the remote control sends IR codes fromits library to the selected device, starting with the most popular code first.
NOTE: If the TV does not turn on during step 6, then slowly press and release CH- to go back through the codes, then press SET UP when the TV turns on.
Charter tv remote control code setup user guides manuals, this should have all the information needed for any charter remote model you have to get you up and running.
Good Luck
Look at this link and either download the manual or repost which model remote you have and we will attempt to further help you...
CHARTER REMOTES LINK
Good Luck ....
SOURCE: I want to know how to program my charter remote to
Your Code is: 11758
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
