May be the wifi is switched off under the router or its in hidden mode, updrade the firmware of the router and then re configure it ... problem fixed for sure
best of luck
Testimonial: "thanks. all fixed. "
The router not detected or "no active network" might be found in the
computer. In this case, make sure that the router is turned ON. If the
issue is not resolved then the router might need to be reset. You need
to press the reset button in the router or switch it OFF and then turn
it ON. This might help in detecting the router and in the proper
functioning of the wireless router.
