Just had ATT uverse installed and now i don't get sound thru my Sony receiver. I have to use the tv's speakers to get sound. I even ran rca cables between the uvers box and receiver and still no sound. When i play a dvd the sound comes thru my receiver as it is supposed to even without the rca cables. The att installer is stumped. Any suggestions? Thanks
SOURCE: att uverse codes/Cisco dvr box
is ipn 330hd the model number for the cisco scientrific atlanta box
SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
SOURCE: No Audio thru Optical input
If its a PS3 please realize that you adjust the sound options using the sound option menu on the ps3, so its possible that you have the PS3 set to RCA cable and not the HDMI therefore the optical cable isnt getting any sound from the TV
SOURCE: have att uverse receiver in bedroom hooked to a
Read in other forums that some lcd tv may interfear with infarated signal....I didn't know this when i had my problem had to put my reciver inside closet away from tv for it to work......
SOURCE: att uverse receiver hooked up to sharp aquos tv, remote quits
first try new batteries and be sure you have pressed the AT&T mode button at the top left of the remote - if you still have issues then on the sharp tv menu - turn off any energy saver mode, Optical Picture Control, taking the picture mode from dynamic or vivid to standard, and if that doesn't work - try changing the backlight settings if your tv has one.
