Replace the FAN. You cannot FIX these. REASON> The fan motor generally turns on a ball bearing or oil impregnated sleeve. These tend to dry or wear down from use or age.
They are low cost devices and replacement is the only way to go.
The Veriton 1000 I have has 50mm fans (length and width). 80mm are the wrong size. They are 15mm thick, 12V, 0.2A. For some reason, these seem to be more expensive than many other fans.
If it's the processor fan that's noisy you can purchase a replacement. The fan and heatsink are normally a complete assembly you can find from many vendors online. This computer has a type AM2 socket; you need to make sure to get a cooling fan for that type. Be sure the replacement will fit into the same space as the original.
If it's the power supply fan thats loud, there may be a couple of possible causes. It may just be a noisy fan, in which case you can replace the power supply. Make sure to get one that has at least the same power rating as the original. Or the fan may be running at its maximum speed. I don't know about this computer in particular, but many computers control the fan speed depending on how hot the processor is (determined by sensors built into the main board). If the fan is running at its top speed, it can be quite noisy. This might be due to a defective power supply or problems with the fan control on the system board
