Call your phone number from a touch-tone phone. During the outgoing message,press 0 and enter your PIN code. The answering system announces the number of messages stored in memory and the voice prompts. To quit, hang up the phone.
Call your phone number from a touch-tone phone. During the outgoing message,press 0 and enter your PIN code. The answering system announces the number of messages stored in memory and the voice prompts.To quit, hang up the phone.
You can't post conmments that contain an email address.
When you are away, you call your number and waiting for the welcome message (your message). When the machine invites you to leave a message you enter your secret code, the one you entered when you configured the machine. (Usually there is default, but since you don't have a manual there is no point guessing (although 123 may do the trick). Some older phones have a code sticker on the underside of phone.)
When the code is recognized the machine starts giving instructions press (number) to (do something).
Go to the base unit.
scroll to the answering machine option.
Under there is a setting for your security key.
you can read what's there, or change it to your own two digit code.
when you call in, during the message, enter that two digit code and it'll go into messages. There's a "toll saver" mode so that the machine answers after two rings instead of 4, so that if you call and it rings 3 times, you know there's no new messages.
Manual: http://www.uniden.com/pdf/DCT648-2om.pdf
Here's the manual: 29869GE2 Digital Answering Machine You will need to set a security code. When you're away you can call your home phone and enter the code to retrieve your messages. Hope this helps.
Go in NOW and edit your PERSONAL & PRIVATE
INFORMATION...
Right now every WACKO on the internet
Knows your NUMBER & INTERNET identity...
(and probably your DEFAULT "pin" code)
((You just gave everything ELSE needed))
With very MUCH ease I could enter your home phone...
MONITOR your rooms... Take your messages... (etc.).
((Find your Name, address & track family members))
You are seconds away from some
SERIOUS IDENTITY theft issues...
Never post personal information on the internet
>> (seriously).
Generally ... You need to clear off that INFORMATION and get paranoid... EDIT it off NOW...!!
On to your question: Your Owners Manual
(please ... oh please HAVE a REAL pin number).
Your page 31: tells you (& the WORLD)... How to
operate YOUR PHONE:
Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}table.MsoTableGrid {mso-style-name:"Table Grid"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Instructions for Retrieving Messages While Away from Home Sony TAM-100 Answering Machine Step I:Set the Remote ID (security code) on themachine itself:
1Press (SET/REC). 2Press (ANSWER ON/OFF).
A voice guide will say: “Pleaseset the security code.To select, pressthe SKIP or REPEAT button.To enter,press the SET button”.
3Set a two-digit number between 00 and 99 bypressing (SKIP/QUICK) or (REPEAT/SLOW).Press (SKIP/QUICK) to increase a number, or (REPEAT/SLOW) to decrease.
Each time you press (SKIP/QUICK)or (REPEAT/SLOW), the answering machine announces a number.
4Press (SET/REC).The remote ID code (security code) is set,and you hear a long confirmation beep.
To change the remote ID code(security code), Enter a new remote ID code (security code).The new code will replace the old one.
Note:If a powerinterruption occurs, the remote ID code will not be erased.
Please See Next Post to Continue (my response exceedsallowable text restriction ;-) ).
When you first installed your GE Digital Messaging System, you heard the code that was auto set for it. Once you are out and away from home, phone home and during the answering machine promp press # and then the promps will ask you for your 'pass word [code]. Please be careful as messages deleted by you, you may not beable to retrieve them. This machine doesn't run by cassette tapes.
~ hope the above helps.
To connect with your answering system:
1 Dial your telephone number from a touch tone phone.
2 When the system answers, enter your Remote Access Code.
The system announces the number of messages and begins
message playback.
3 Listen to your messages
Change remote access code Press [*] [#]. Follow prompts to set new code.
