Jus purchased a Proscan 26' T.V from Arrons Rent a Center. The Proscan remote isnt working. The batteries are new and the light flashes on the remote but nothing is working on it. Any suggestions?
Proscan tv remote wont work somehow i got tv on hdm12 and wont let me back on tv so have nothing. im not good with tvs but this ones a piece. can i get any help
If this TV came with an universal remote, try pressing the TV key. Sometimes it works.
If that did not work any other RCA, GE, Proscan universal should work.
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST For Universal Remote Control brands listed below, please use accompanying Proscan codes and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to operate Proscan model. Proscan codes for Sony TV=8003,8012 Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216 Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
You need to isolate the problem. 1) Unplug the TV for a few seconds and then plug it back in.
2) Operate the TV with the buttons on the TV. (Channels etc) I presumed you have scanned in the channels. If no problem found then do this for the remote. Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones.
Now try the remote to see if it works. If it fails you will need a new remote.
does rca make proscan? if not who does
remote doesn't work for off/on but can change stations
Contact AArons . It should be under warranty if you just purchased it.
