Question about Kodak EasyShare C315 Digital Camera
All of a sudden my Kodak Easyshare 530 will not transfer pictures to my computer, I have reinstalled software, still does not transfer. Can you help me?
    Genius:
  • Kodak Master
  • 1,099 Answers
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If you suspect it could be directly related to your software.
You need to follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Posted on Jan 11, 2010
6ya staff
SOURCE:
Kodak Easyshare DX7630 Can't Tranfer Pictures
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Kodak's.
Apr 24, 2012 | Kodak EasyShare DX7630 Digital Camera
Computer does not respond to camera being on and plug in
  • Start EASYSHARE Software.
  • From the menu bar, select Help > About Kodak EasyShare software.
  • Note the software version. If you have Version 8.0 or later installed on your computer, review the help information for Transfer Pictures.
  • From the menu bar, select Help > Kodak EasyShare Help.When the Welcome to EasyShare Software window appears, select Transfer pictures, then read the help information.
  • If you do not have Version 8.0 or later installed on your computer, go to EASYSHARE Software Downloads, then follow the instructions to download the latest version of software. Approximate download time is 5 minutes for Cable/DSL, or 2 hours for a dial-up connection.
If that doesn't solve your problem you can manually add your pictures/videos to easyshare software.
  • In easyshare Software, select My Collection, then select Add Pictures. The Add Pictures screen appears.Look at the Select a location field. If the My Files folder is collapsed, click the + to open the folder.In the Select a location field, select your camera folder, for example: M381 Digital Camera. Thumbnails of the pictures/videos on your camera internal memory, and on a memory card if one is in your camera, appear.
  • Select the pictures/videos to add to EASY SHARE Software, then click Add Pictures. To add all the pictures/videos in the folder, click Add Entire Folder.Click Done.
Thank you !!
Jun 25, 2010 | Kodak Easyshare C813 Digital Camera
How do I delete photos from my internal memory
KODAK EASYSHARE Software is only compatible with KODAK EASYSHARE C-, CD-, CW-, CX-, DX-, LS-, M-, P-, V-, and Z-Series Digital Cameras; and DC4800 Digital Cameras. If you have one of these camera models, go to Step-by-Step Solutions and Repair tool to help resolve this problem.
If you have one of the other digital cameras, you cannot use KODAK EASYSHARE Software to transfer pictures to your computer. Use the software that came with your digital camera to transfer the pictures to the computer. When your pictures are on the computer, you can use EASYSHARE Software to edit, share, and print your pictures.
Mar 21, 2010 | Kodak EasyShare One Digital Camera
Problem downloading photos from camera to computor
KODAK EASYSHARE Software is only compatible with KODAK EASYSHARE C-, CD-, CW-, CX-, DX-, LS-, M-, P-, V-, and Z-Series Digital Cameras; and DC4800 Digital Cameras. If you have one of these camera models, go to the Step-by-Step Solutions and Repair tool to help resolve this problem.
If you have one of the other digital cameras, you cannot use KODAK EASYSHARE Software to transfer pictures to your computer. Use the software that came with your digital camera to transfer the pictures to the computer. When your pictures are on the computer, you can use EASYSHARE Software to edit, share, and print your pictures. Hope it helps you.
Mar 06, 2010 | Kodak EasyShare One Digital Camera
Transfer problem with kodak MD1063
With the cam connected , open the easyshare software ,bypass the transfer window then click on the ADD PICTURES icon on the top left,under SELECT A LOCATION click on the model no. of the cam. Tag all the pictures you would like to add, then click on ADD PICTURES. Click on DONE once finished.
Jan 07, 2010 | Digital Blue EasyShare MD1063 Digital...
Why can't import my pictures into the computer?
Have you downloaded the Kodak Easyshare software? It will be easier to transfer picture from the camera to the computer also easyshare software has feature to enchance picture download not to mention that you can send picture thru email using the esayshare software. To download the software visit www.kodak.com/go/easysharesw.
Transferring pictures/videos with the USB cable
Turn off the camera.
2 Plug the labeled end of the USB cable into the USB port on your computer.
3 Plug the other end of the USB cable into the USB port on the camera.
4 Turn on the camera.
Note: EasyShare software opens on your computer. The software prompts you through the transfer process.
If still having issue importing picture from the camera to the computer call Kodak support line at 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z730 Digital Camera
Macbook says file type "unrecognizable" from Kodak M763
It seems that your computer doesnt recognize jpeg files . Download or reinstall quicktime to fix the problem, you can get free download at www.apple.com
Mar 25, 2009 | Kodak EASYSHARE M763 Digital Camera
I have a Kodak EasyShare C530 that I use all the time. Lately the camera won't connect to the computer to transfer pix. I just get the image the camera is facing-no black screen before the connection is...
Hi, Here are a couple things you can try to isolate the cause of this problem. Here goes: 1. See if the camera will connect and transfer properly on a different computer. If so, then the camera is fine. 2. Uninstall whatever software you are using to transfer pictures. If you have not installed any software, it is possible the OS is doing this for you. If you have WindowsXP or Vista, you do not need any software for basic transfer. If you are using the Kodak software that came with your camera, try uninstalling it and re-installing it. Hope these tips help.
May 21, 2008 | Cameras
Computer will not "see" the camera.
you need to delete the software and reinstall it
Aug 24, 2007 | Kodak EasyShare C653 Digital Camera
Transferring pictures from my Kodak EasyShare digital camera to my computer
This error message means that the preferences in EasyShare software are set to save pictures to the CD-ROM drive or some drive other than your hard drive. To correct this, follow these steps: Start EasyShare software. Select Tools > Preferences. Select the Transfer tab. Below "Select the location on your hard disk where you want to copy transferred pictures," select Browse. Browse to the desired location on the hard drive where you want to transfer your pictures. The default location is: For Windows 98/Me Operating Systems: c:/My Documents/My Pictures/Kodak Pictures For Windows 2000/XP Operating Systems: c:/Documents and Settings/user name/My Documents/My Pictures/Kodak Pictures Select OK to return to Preferences, then click Apply and OK to save and close the Preferences. Reconnect the camera, and transfer the pictures.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Kodak EasyShare C315 Digital Camera Logo
156 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
