My washer stop working half way, all LED on control panel appears on, after that it not responding when i press any button on the control panel. But after few days, it might work properly again. Help.
I had this problem when I used TIDE 2X detergent (thinking 2X was the same as HE). This happened several loads. I had bought several jugs of Tide (larger ones won't fit in drawer). Somehow grabbed HE one next time and didn't have this problem. Tried the 2X another time or two with again the washer stopping and LED lights on/unresponsive.
Solution was to not use anything but HE detergent.
Still having problem with Fabric Softener dispenser.
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS
SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL
WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL
WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS
ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE
ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH
SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM
AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND
PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS
LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER
THAN NINE: A=10 B=11 C=12
D=13 E=14 F=15
"EXAMPLE CODE F1: THE FIRST
DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A
WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN
TIMES AND THE START INDICATOR LIGHT WOULD
same problem... Is it controller problem?
I'm having the same problem as I turned on my washer and all LED is on and the machine did not respond to any buttons pressed. please assist in informing on this issue
i have the same problem on my samsung WA7587 6.0 KG WASHING MACHINE.
ALL LED ARE LIT AND WOULD NOT RESPOND ..
AFTER A FEW DAYS IT MIGHT START WELL... AND THEN AFTER A WHILE IT WILL STOP AND SHOW THE SAME PROBLEM.. HELP!!! ARE THIS INHERENT IN SAMSUNG BRANDS..??
