Pentax *ist DL Digital Camera Logo
Posted on Jan 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't see symbols in viewfinder of a Pentax ist dl.They are completely blurry and unreadable
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Pentax Master 102,366 Answers
  • Posted on Aug 23, 2012
Pentax Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10433855
Points
622693
There's a diopter adjustment lever just above the viewfinder. Adjust it while peering through the viewfinder. This may be easier if you remove the rubber eyecup.
For further details see the "Adjusting the Viewfinder Diopter" section on page 39 of the manual.
5 Related Answers
Anonymous
  • Posted on Dec 20, 2007
SOURCE: Flash won't work
Try in custom menu I think. Switch shutter release whilst charging firmware switch whilst flash charging a couple of times. Had sinilar thing with ist DS after firmware update.
Anonymous
  • Posted on Jan 02, 2008
SOURCE: lost instruction manual
Send it to me, I will operate it for two years then send it back.
A
Anonymous
  • Posted on Jun 22, 2008
SOURCE: Pentax ist Dl
Happened to me too, your flash circuit is broken. No solution but to resort to warranty ;)
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Oct 24, 2008
SOURCE: Pentax *ist DS digital SLR Autofocus problem
Being an SLR camera, you should try another lens. It may be a servo fault in the lens. If the lens is okay, then it can be anything in the lens sensing, lens control drive circuits, and or lens to camera interface area. This would have to be properly diagnosed and serviced.
Jerry G.
Anonymous
  • Posted on Mar 17, 2009
SOURCE: AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
The problem is with waking a sleeping Pentax ist dl: touching the shutter button doesn't reawaken it. To enable the ist dl to shoot requires turning off the camera and of course switching it on again.
This is a common problem with all the ist's. Try cleaning the battery contacts inside the camera with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Using a 500mm fixed aperture lens on a Pentax ist
Use "exposure compensation" (the button with a plus/minus symbol). It allows you to lighten (toward the + side) or darken (toward the - side).
1helpful
Does a Quantaray Tech-10 75-300 lens fit a Pentax *ist DL digital camera?
Quantaray makes lenses with a variety of mounts. If the lens has a Pentax mount then it will fit onto your camera. If it has a Canon mount, for example, then it will not.
PENTAX IST DS PROBLEM WITH INTERNAL FLASH
First make sure the camera is not set to No Flash on the shooting mode dial.Also, in P, Tv, Av or M modes the flash reverts to manual and must be raised manually by pressing the button next to the viewfinder.
Lost instruction manual
Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
