I am not able to open the drawer to put soap, bleach and Fab softner in it. I think the detergent cup is preventing the drawer from opening. How can I get the drawer open with out breaking anything?
Thanks for your help....
Here there is a user guide and instructions of a similar washer model.
http://www.laundrymanuals.com/manuals/mfg/lg/wm2496h.html
and also all available LG washer manuals to download.
http://www.laundrymanuals.com/manuals/mfg/lg/lg_frontload_washer_product_list.html
Have a look of how top lid is mounted.
Hello sir
Try this, use an oil (could be a lubricating oil, else even hair oil wud do) main purpose is to remove friction, so place ample oil on the edges of the cup or the place of openings of the cup and simultaneously shake carefully to make space and agitate the oil to go deeper to make it free...!!! Waiting for ur reply...!!!
Thankyou
Just do as i directed and u will certainly get it opened..!!!
Thankyou
Just shake open the dispenser towards left and right outwards simultaneously pouring few drops of oil into the edges and corners... once the dispenser comes out, then clean all the places with damp cloth to remove oil stains...!!!
if ur goin to try to remove the soap dispenser, unless it is an automating dispenser.. it can help u to lubricate, normaly they get struck due to damp conditions...!!!
Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
Take out the inserts and rinse them and the drawer thoroughly.
Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
Can I remove the top lid of the machine to get acess inside of the soap drawer?
Oil will not fix!!! If you knew about this model there is a soap dish inside the drawer that is blocking it from opening. How is oil going to help ?
Remove the machine's top cover to get access to the drawer assembly. Remove two screws that hold it in. Slide out a bit. Pop the drawer handles clips with swear driver . The assembly has clip on top. Clean soap out of the drawer so that part move smoothly again. You might try to run the machine a few times this might clear soap with taking things apart.
Looks like mine is different model so may not be the same.
I want to remove the plastic dividers in the detergent & softner area, its a mess. how can i do this with out breaking them?
