Samsung SGH-D500 Cellular Phone Logo
Posted on Feb 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung D-500 Bluetooth Problem
Hi from my samsung D500 mobile bluetooth i can able to send the file to any other moblie(like nokia, sonyerricson etc) but i can able to receive the files from only samsung moblies but not from any other mobles. Suggest me what to do?
my e-mail ID is [email protected]
  • Anonymous Feb 08, 2008
    no function bluetooth,infrared
Anonymous
Level 2:
  • Expert 91 Answers
  • Posted on Feb 08, 2008
Anonymous
Expert
Level 2:
Answers
91
Questions
0
Helped
45907
Points
151
The D500 is an odd fellow when it comes to bluetooth, it has a compatibility problem that makes it impossible to send anything from other brands than samsung to it.
There is no easy solution to this problem other than using a computer or another samsung.
Sorry, but in this perticular case ... Samsung sucks big-time :-(
9helpful
2answers
My samsung GT C3222 mobile is not accepting files through bluetooth but could send. can someone help me solve this?
My samsung GT C3222 mobile is not accepting files through bluetooth but could send. plz help me solve this?
Hi, My Samsung mobile is GT-C3303. I have problems in connecting to the bluetooth device on my laptop machine to transfer the music files. I have tried both 0000 and 9999 and 1234 but nothing is helping...
you have to pair your samsung phone to your laptop first before you can start sending and receiving files through bluetooth.
an option is, turn the bluetooth on your laptop on, then the bluetooth of your mobile phone on. on your phone, search for devices, then once you see the name of the bluetooth device of your laptop, tap it then choose connect or pair, you will be asked for a passkey (you can input anything try 0) or in some devices wait until a pop screen appears which will contain the passkey usually 5 to 6 digits. then click ok
another option is (i tried this using my samsung corby wifi and a samsung n150 laptop and it works just fine) make sure that the bluetooth on your laptop and phorne is turned on. on your laptop click on the bluetooth icon or click the file you want to send, then right click, then choose send to bluetooth, your laptop will then search for available devices, just choose your mobile phone then automatically there is a popscreen which has a passkey, then click ok. on your phone you will be asked to allow to connect thru the laptop, just click ok, then make sure that the passkey matches between your phone and laptop. (usually it is automatic, you just need to click ok) you should be able to send and receive files thru bluetooth on your phone and laptop
How to connect samsung tocco mobile to another samsung tocco mobile using bluetooth?
Turn on the Bluetooth wireless feature.
To turn on the Bluetooth follow the below steps,
1. In Menu mode, select Applications > Bluetooth.
2.. Select the circle in the center to turn on the Bluetooth wireless feature.
3.. To allow other devices to locate your phone, select Settings > On under My phone’s visibility > Save.
To connect other device to your mobile
1. In Menu mode, select Applications Bluetooth Search.
2. Select and drag a device icon into the centre.
3. Enter a PIN for the Bluetooth wireless feature or the other device’s Bluetooth PIN, if it has one, and select OK.
When the owner of the other device enters the same PIN or accepts the connection, pairing is complete.
After connecting you can start sending the files from one mobile to another mobile.
To send files follow the below steps.
1. Select the file or item from one of your phone’s applications that you want to send.
2. Select Send via or Send URL via Bluetooth, or select More Send via Bluetooth
Thank You
1helpful
How can i access net through samsung sgh-l700 connet to laptop using bluetooth
connect mobile with pc through pc sutidio through bluetooth their is a option in pc stuido that connect moblie through bluetooth and then u open netwrok wizard and then connect through internet
3answers
My new samsung e1410 mobile have probleam with bluetooth .I can't able to send file via bluetooth to any other mobile.where other mobile able to send them that files from their mobiles but I can't able to...
Your phone might not support blue tooth file transfer. Call your service provider and ask, they should be able to tell you. Also the file you are trying to receive/send might be to big
3helpful
Samsung sgh-d500, blue tooth and infrared not functioning
on phone go to menu/settengs/ok/scroll down to connectivity/ok/two choices here, bluetooth/infrared/ok/look at your choices here that should get you going? any problems let me know,
Sending Videos from D500
The answer to question 3: If you right click on the file, it should say open with. Click on this and it should give you a recommended programe to open it with. Could you also tell me if it has a memory card. If it does, you merely need to take this out of the phone and take it into a photographic shop. They will be able to put them onto disc for you.
2answers
D500.
For other mobiles to send some data to you, bluetooth in your mobile should be in discoverable mode. Try changing the setting of bluetooth not to be kept in hidden mode. once your mobile is discovered by others, pair your mobile with them. Now you can receive all the files to your mobile, but only the supported format files like mp3, jpeg picture,etc
2answers
Mobil
Hi there mate
I had the exact same problem go to google and search up uploading java games to samsung d500 you need to download the softick tool and the ppp for samsung d500 thats the application my solution search google theres a site thats give you the exact details and the sites to download the exact software your after hope this helps an if you have the time please rate me that would be great
thanks again
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
