That seems strange- try restarting your computer, or if that doesn't work, check your browser settings and make sure you don't have a weird key-bind set to the space bar. If all else fails, it might be easier to just reinstall your browser. I recommend Firefox, but Chrome is a strong browser as well.
Look closely at the space bar. try to lift it on the right side and on the left. The bar may have popped out of place. Specifically a metal rod that holds the space bar in place. Or the space bar is not resetting fast enough, ( soda, honey, something sticky) causing the bar to reset slowly.
hit the dash that is ABOVE and to the left of the OK then hit the space
bar on the bottom. Space bar is the widest key on the bottom and
actually looks like a typical keyboard space bar.
Turn it upside down and tap it.There may be some thing caught under the space bar.If not then gently pry the space bar off and clean it.It may be sticky.
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
The space bar on your unit is on the bottom of the keyboard, next to the "M" key. It looks something like this [, but on it's back. Let me know if this helps.
If the bar works when you hit right in the middle try reinstalling the bar the metal rod must go under the tabs on the keyboard, if it won't at all you probably need a keyboard.
