The parts diagrams online show some little parts in the drive train, thrust washers and idler/drivers. Are all those parts accounted for and in place? Is the polarity on the motor turning it the proper direction? Hope you can run it with a cover open to see what is happening or not happening. Can you turn the paddles by hand and the motor turns with it?
Need to know what cable you are asking about. Is it the starting cord for pull starting the engine or one of the auger or drive control cables ??
Can you post a picture ??
You have probably fouled the spark plug (got a heap of black carbon on it) remove the spark plug wash in some petrol then use a wire brush vigorously brush between the contact points on the plug then reinstall. & lastly don't forget to push in the choke when you get it fired up next time.??
Pull your spark plug out and see if the cord will pull out, if it does than that means your cylinder is full of gas which is a result of ethanol in the gas causing the needle valve to leak causing fuel to siphon from tank to cylinder, pull your carb off and put a carb kit in and you will be blowing snow in no time,if this isnt the problem then enjine may be seized up and its time to replace blower. Good Luck!
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
