SOURCE: memory card
Did you just buy this card or have you had it working for a while and now this is happening?
From everything i have read about your camera, they won't take a 2 Gig card. A 1 GIG card is the biggest that is compatible with this camera. If the card is new i would take it back to the store and see if they will let you exchange it for a 1 GIG card.
If this just started happening after using it for a while -- it could be a problem with the card or the camera. Try putting in a different card and see if it will let you format that one. If it does you know for sure the problem is with the card. If you keep getting the same message no matter what card you use, i would phone Kodak. But, according to Kodaks own site, 1 GIG is the biggest card that is compatible. Sorry I couldn't be more help.
Good Luck.
SOURCE: MY Koday EasyShare C530 not supporting 2GB memory
This is from the Kodak website, bad news:
Question
Can I use a 2 GB Secure Digital (SD) memory card in my
KODAK EASYSHARE C-Series Digital Camera?
Answer
No, your digital cameras is not compatible with 2 GB
SD memory cards; your camera accepts a maximum 1 GB SD card.
Hope this helps.
SOURCE: I have not been able
The C530 uses MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
