LG KU990 Viewty Logo
Gav Bowser Posted on Jan 09, 2010
Hi my lg viewty keeps beeping whilst charging what is the problem please it beeps when i plug the charger in and then it keeps giving off the same beep all the time
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
790
Points
Same, for me it was a dodgy charger
  • shadie2000 Apr 17, 2011
    Hiya! I hear ya!~... You have exactly the same problem as me! My phone was fresh out of the box brand spanking new and it still beeps its arse off!.. Im not sure what it is either and I wish I knew cos its a pain in the **** having to charge it before going to bed.. And if you put it on silent you cant hear the alarm. I've even looked in the book to find out if its something I can fix but nada!... Goodluck with finding the answer. I'll keep looking to see if someone found a solution to our problem.-)
MY i pad will not charge
As soon as you connect your iPad to a working charger, it will beep. If you plug in the cable and you don't hear the beep, assume something is wrong. Just find out what, the cable or the charger.
Don't try to charge the iPad with a computer, because the 500 mA a USB connector from a computer can give, is not enough even to start.
But you can use a computer to test the cable, because the iPad should beep and say on the screen not charging.
If there is no beep when connecting to a computer, you have to use another cable. If it beeps, buy a new charger. 5 Volt 2 A. The best an Apple charger.
1helpful
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 • Vacuums
Ac adapter beeping
There are a few things you may check why the laptop charger keeps beeping. Click the following link to get details:
http://www.chargerbuy.com/blog/laptop-charger-beeping/
1helpful
My charger keeps beeping a very faint, high pitched beep, its a T135S1305 Satellite and it isnt charging my computer, this happend once before and started charging again the next day.
i had the same experience like you do, the best solution is buy a new charger before it break your laptop...
my laptop is already broken because i didn't change the charger
please rate
1helpful
3answers
Phone won't turn on, screen just flashes
Sure, request you to get in touch with the dealer from where you bought the phone because at this is the new phone and might be under warranty, so no need to do any technical thing from our side
1helpful
Lg Viewty wont charge, wont start
try with a new battery your could have give up
2answers
LG VIEWTY WON'T CHARGE PROPERLY
I've almost thrown my phone out of the window because of this problem. I really need a solution, I tried changing my charger and cleaning out the socket where it goes in but nothing works. it Just keeps beeping and beeping. This isnt really a solution, more of an agreement of how annoying this is!!
Charging
It's beeping because the battery is completely dead and needs to charge. If beeping doesn't stop after a while of charging, you may need a new battery or a new charger.
13helpful
2answers
Cell phone won't charge/or hold a charge
i had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm :)
Jun 23, 2008 • Cell Phones
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
