I am trying to hook up wireless headphones in a manner that wiil also let others hear the TV while I use the phones.I am also running a Bose system with a receiver which may add to the problem. Is there a fix?
Hello depends on how you hook it up as thee are several ways.
many receivers will output sound through the headphone jacks even when the speakers are left on.(my receivers require that you manually turn speaker A off when using headphones)
it may be possible for you to connect the headphones to a tape output but this will require headphones that have a volume control on them or an external.volume control knob.. You may encounter a problem as I am not sure if a tape output will provide enough signal to drive a pair of headphones. this would not be a problem if you use a pair of WIRELESS headphones as they have their own power source onboard..
A set of wireless headphones could also easily be connected to the output on the back of the TV but assuming you have your receiver plugged in to the TV audio out you may need a couple of Y adapter cables.
Also if your receiver has a pair of PRE OUT jacks those would work to power a set of wireless headphones may also power a wired set but once again not sure on power as I have never needed to try it.
Hope that helps a bit
Testimonial: "thanks for the input. This is the best solution I have received to date. I can not wait to try them Arthur"
Bluetooth Headphones V4.1 Wireless In-Ear Noise Cancelling Sweatproof X7 Headset for iPhone6/6s /iphone7,Samsung Galaxy S7/S7 edge and Android https://www.amazon.com/gp/product/B01LARW6UI/ref=s9_acsd_hps_bw_c_x_6_w
