I have the same prob. and the reset procedures for other models doesn't work. The power will not turn on if the resume button is depressed.I have the same prob. and the reset procedures for other models doesn't work. The power will not turn on if the resume button is depressed.
AnonymousMay 02, 2008
my copier shows full is there a way to reset????????my copier shows full is there a way to reset????????
I have the same printer with the same message..."Waste ink near full"
If you know how to clean out the printer please let me know.
Thanks....I have the same printer with the same message..."Waste ink near full"
Thanks....
AnonymousMay 12, 2008
I have the same printer with the same message..."Waste ink near full" how will i fix it.........I have the same printer with the same message..."Waste ink near full" how will i fix it.........
On Canon Support, the fixes are one of two things:
1. Turn of printer (holding on/off button for about 1 second) and wait approximately 10 seconds. Turn printer back on. If on/off button does not turn printer on/off, then unplug the printer.
2. If the above doesn't work, your printer may need to be fixed.
What's not said on the website: What does the error "Waste ink near full" mean.
It is not recommend you try to fix it yourself, you can try to manually reset the error code, but if the waste ink is really nearly full and you reset it, it could damage the printer pretty severely. Here are manual reset instructions for a similar model printer, it should work on the F60 if the buttons are the same:
1) Enter Service mode by pressing: menu-copy-#
2) select: Test Mode
3) select [8] printer test in test mode
4) select 3 [eeprom clear]
5) select 0 [ink count]
6) press the [stop/reset] key (returning to the state of 3), and press the [on/off] key
If that doesn't work try this one:
1) Enter service mode by pressing MENU,COPY,SCAN,COPY,COPY
2) Select TEST MODE
3) Select (8) PRINTER TEST in TEST MODE
4) Select 3 (EEPROM CLEAR)
5) Select 0 (INK COUNT)
6) Press the SET key
7) Press the (Stop/Reset) key, returns to the state of 3, then press the ON/OFF key
Hi
This works on the F30, F60, and F80. Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error) Solution: Press the <RESUME/CANCEL> button to clear the error (1700) Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible. Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error) Solution: Press the <RESUME/CANCEL> button to clear the error (1700) Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
HiHello try ths
ok
Okay, follow these steps below to reset this message:
1) Enter SERVICE MODE. By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Then call Canon 1-800-828-4040
Just inform them that you
have already reset the counter so the error is gone, but you needed to
know if there is a part that needs cleaned or replaced to prevent
further problems.
Hi. I actually had to reset the waste ink volume counter on my F60 and found a solution posted by NerdRUs that helped me. So I copied and pasted it below: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Hi
Thanks....
Machine says waist tank near full. What do I do now?
