Cameras Logo
Posted on Jan 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pentax optio S displays the error A90 it seems a firmware problem that need a file to recover it but I can't get it
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
436
Points
I hav got the file. I fixed my Optio S with the A90 error and it is working again, but now all the pictures look out of focus. Damn it!
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jan 08, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200811
Points
38521
There are no firmware updates for the Optio S.
A90 error code
I am looking john honest...JB
How do I solve my A90 prob?
I just fixed a friends Pentax Optio S4i.
You want to extract this file.
File name : O4IE101W.EXE
Format your SD card in my computer. Open the O4IE101W.EXE on your desktop. It makes the file fwdc124p.bin. Put the fwdc124p.bin on the SD card.
I did save this file on the flash card.
Then I fully charged the battery (I got this from the Pentax site)
I opened the "secret menu" by pressing the MENU-FLASH and the POWER button at the same time.
Once menu opened, I pressed the FOCUS twice then (FLOWER, MOUNTAIN, MF) symbol twice after this two toggles to the right with the OK button.
Then press the MENU button once again.
So the menu screen open now.
Down toggle of the OK button, go to ROM UPDATE then go down to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Once this has been done, turn your camera off.
Turn camera on again opening your camera with the MENU+Power ON procedure...finally this should be posting "Complete" after the "Loading"
When it shows Complete, turn camera off.
You are finished and your camera should be ready to work again.
At least this is how I fixed my friends A90 error message.
The firm ware is here:
http://www.pentaximaging.com/support/manuals-and-literature/
navigate to your camera
2helpful
2answers
ERROR A90
from internet:
An A90 error means that there is a electrical fault on the main printed circuit board, and can only be repaired by sending the camera in for repair through your Pentax dealer.
I hope that your question has been answered to your satisfaction.
With kind regards,
Wim van Kleef
Pentax Digital Camera Support Team
(with cut and paste from ; )http://forums.dpreview.com/forums/read.asp?forum=1028&message=23626964
my sugesstion is after reading this go to your pentax supplier and ask them for a investigation repair (the don't repair yet but investigate what is defect and how much the repair costs would be (normaly is that you pay a amount of money and mostly it is deducted from the repair bill if you decide to let it be fixt. (ask them if they would act so , otherwhise sue them for a not good product)
A90 error Optio S4
Gerrit
So is jou probleem uitgesorteer ?
Optio S4i will not turn on?
Your problem is part of the dreaded A90 error code these cameras get. My camera had this last year and updated firmware cured it till this month when my wife let the battery go dead and the problem returned, but firmware update won't fix it this time around.Go to Pentax site and download new firmware for camera. Follow instructions that come from Pentax on the download to install software. Its pretty easy. These are cheap cameras as far as Pentax is concerned. They only work for about 2 years, based on other users and my experience. Good luck
Where do I get the file:fwdc110p.bin ?
http://www.badongo.com/file/707791
You can download the file from the above site - I think this might be the exact reference. Then go to the most recent entry on this site for the secret menu process http://forums.steves-digicams.com/forums/view_topic.php?id=82905&forum_id=24&highlight=A90
Rember to place it on your card at the same level as the DCIM file, not inside it like I did at first. It came zipped so you will need to use Winzip. I will now try and polish this a bit on that site while it is still fresh in my mind.
4helpful
3answers
Error A90
The a90 error message, relates to an electronic fault on the main printed circuit board of the camera.
1helpful
2answers
Freeze Up
A- I have a Pentax Opio S hence I had to get the "fwdc110p.bin" file here:
B- Drop this file on your SD Card at the root directory (same level as DCIM folder) or as described by the following link and then close your camera to OFF:
Attention: Do not load this file yet onto the camera i.e. the menu+power on procedure, follow step C first...
Important!!! Insert a fully charged battery or connect to an external power source.
C- Open the now infamous "Secret Menu" in order to re-initialize your camera prior to re-installing the new firm ware: Simultaneously press MENU + Flash symbol button + Power ON...a white screen with data written in black should show.
Then a sequence of buttons must be pressed: 2 times the focus button (flower, mountain, MF symbols button) followed by 2 toggles to the Right of the "OK" button...then press MENU once and voile...the Secret Menu appears!
Using the down toggle of the OK button, go to ROM UPDATE then go down to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Once this has been completed, turn your camera off.
D- Load the firm ware by opening your camera with the MENU+Power ON procedure...finally this should be posting "Complete" after the "Loading" message, instead of the "Error!" that we initially kept on having.
Your camera should be working perfectly! Only thing is that you will have to redo your personal settings on it from scratch...but hey, this is much better than to wait for months to get your camera back from Pentax and save that money for your next photogenic trip!
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
