Question about Acu-Rite Audio Players & Recorders
Can I download instructions to set my Acu-Rite indoor/outdoor thermometer ? #0754 #WC C0018
I need insdtructions for an acurite indddo-outdoor wireless instrment #00592W. Help Charles Henley
Posted on Apr 16, 2010
    New Friend:
  • 3 Answers
Take a look at Chaney Instruments http://diplodocs.nl/references.php
Wireless Thermometer with Sensor
Model 00735 ??
Posted on Jan 15, 2010
6ya staff
SOURCE:
Why isn't outdoor temperature displayed?
Try repeating the initial set up procedure. Remove all batteries from outdoor and indoor units. Install known-good batteries in the outdoor unit. Allow time for the outdoor unit to begin transmitting data. Install known-good batteries in the indoor unit. You should see the outdoor temperature displayed.
Feb 09, 2016 | AcuRite Acu-Rite 00621 Wireless Weather...
ACU RITE Wireless Thermometer Model L5C0668TX cant set the date
I have misplaced the user manual for the
Acurite L5C0668TXACU RITE Wireless Thermometer Model L5C0668TX. Where can I get another?
Jul 19, 2012 | Acu-Rite Acurite Wireless Indooroutdoor...
I need to reset the time and do not have the instruction manual.
I Have a Acu-Rite Acurite Wireless Weather Thermometer 604RX and it came without an instructions for use. Is there any web site I can go to in order to get the instructions or could you e-mail them to me? Thanks, Pat
Apr 26, 2011 | Acu-Rite Acurite Wireless Weather...
Acu-Rite Wireless Thermometer indoor/outdoor, the only identifying number I can find is inside where the batteries go, a sticker says: 0417. Question: 1) On the indoor piece, I can set the clock to the...
Before attempting to set the time, let the outdoor transmitter sync with the indoor receiver. Once that's done, you'll be able to successfully set and retain the date and time.
Jan 14, 2018 | Acu-Rite Acurite Wireless Indooroutdoor...
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Nov 24, 2009 | Acu-Rite Audio Players & Recorders
1,818 people viewed this question
Top Acu-Rite Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you an Acu-Rite Audio Player and Recorder Expert? Answer questions, earn points and help others
