Watches Logo
Posted on Jan 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Day of week has jue yesterday min what does that mean instead of having mon, tues, wed
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Jan 08, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813053
Points
13579
You have day ring in Dutch, not the English. Try to find out if there is English by slowly turning (changing) days.
Rate me, plz.
What are the hours of the aldi store in raymond terrace
22 Pt Stephens Rd, in this week or 2 it is open
Mon: 8:30 - 20:00 Tue: 8:30 - 20:00 Wed: 8:30 - 20:00 Thu: 8:30 - 20:00 Fri: 8:30 - 20:00 Sat: 8:30 - 19:00Sun:closed
Dec 22, 2016 • The Watches
I cant get the day of the week right it reads wed when it should read mon
Check the year is correct. If not set to correct year, it will show different day.
Oct 19, 2015 • Watches
1helpful
1helpful
2answers
Just bough a Subaqua Noma III Chronograph Watch and the Day of the week...where it says mon tues etc...changes at 3 am instead of at midnight. how can i fix this
you cannot fix this. Unfortunately for movements to be that exact they cost a lot of money and the movement inside your subaqua is not that high tech and accurate. This is what makes watch really expensive the little things like this. Unless you are buying a 10k watch , they usually are not going to have the top of the line movement . The movement you have in your watch is an ISA 8173 and that is as accurate as the watch will get.
1helpful
How do i set the day of the week on my Invicta subaqua noma 6125?
For Invicta chronographs to set the day you need to pull the crown out to position 3 (2nd click after releasing the crown/ furthest crown position/ same position to adjust time). You can only set the day by rotating the crown clockwise. Every 24 hours of clockwise rotation will move the day indicator forward 1 position (Mon>Tue, Tue>Wed, etc). If your watch is set one day ahead of the correct day (Its Tuesday but the watch displays Wednesday for example) you will need to rotate the crown clockwise through the entire remainder of the week in order to get to the correct day, you CANNOT rotate the crown counter-clockwise in order to move the indicator back a day.
I HAVE SWISS WENGER MOUNTAINEER WOMENS WATCH. WHEN I TRY TO CHANGE THE DAYS OF THE WEEK.IT SAYS MER LUN DIM WHAT DOES THAT MEAN.THANKS
Some watches are designed to be international and thus have alternative names for the days of the week.
I think "mer, lun, dim" are Mon, Tues, Wed". It should be possible to re-set your watch to give the English version.
If you do not have a manual, you can get one from their web site "www.wengerna.com/mountaineer-titanium-72619" as a PDF file.
4helpful
Setting day and date - the day and date change at the wrong tome of day
To sync the correct 12 hour with your day you need to set the date to the day before (if today is Wed 21, then make sure the day window reads Tues 20). Then spin the analog hands until the the date window turns to Wed 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm. The day (Mon thru Sun) sometimes needs to be set seperately from the day; it may take a couple of tries but use the directions above and patience and you will achieve your goal.
That's how you do it. If you need more clarification let me know.
3helpful
How to set day of week mini dial?
Pull out the crown and advance hands forwards. When the hour and minute hand will pass 12 o'clock (midnight), you will notice the day hand will jump to the next (following) day. Advance hands as long as needed to reach the desired day.
Rate me, please.
Day in both english and french alternately.
retailer contacted rotary.
apparently there is quite a delay (hours) before the day eventually chages back to English. In other words it doesn't change immediately after 12pm but sometime early in the morning?
The moral of the story is that you should be in bed before 12pm and not to take any notice of the day on your watch since it will still be yesterday and in French?
Jun 11, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
