The Bosch Logixx 8 washers indicate an F37 error when the temperature sensor is defective. Sometimes this can happen if the incoming water line gets too cold. If that is the case, pressing the temperature button twice may help. (You should see a snowflake in the top left corner of the LCD screen.) Otherwise try thawing the water pipes.
If the problem isn't cold/frozen water lines, then the temperature sensor is faulty, the wiring between the sensor and the control board could be damaged or the control board has a problem getting the temperature information. Check the sensor and the wiring first. Often there is a sheet inside the washer (near the control board) with the expected resistance across the sensor and other parts. Unplug the washer before testing.
Please add a comment with the model of the washer for a parts diagram or price list. If your washer is under warranty, contact Bosch about the error.
the machine has a defrost function, pressing the temperature button twice will start this and show a snowflake in the top right hand corner Press the temperature button twice, ( A snowflake will appear in the top left corner) this acts as a defrost button. F37 will probably occur more often if your machine is stored in a outhouse. or try thawing out the water pipe.
