This is what we call a "delayed ignition",(gas is not being ignited right away), gas builds up in the chamber and then lights causing a boom. The cause of this problem could be from having dirty burners or ignitor not position to ignite the gas right away or your ignitor may not being glowing enough to ignite the gas being released, check all, Good luck.
Here
is a tip that will help you try to figure out why your furnace is not
working.
Basic
Furnace or Heating System Troubleshooting
heatman101
is it from the fan ?
More info needed, do burners light? does fan come on?
Are you talking about the motor? The motor kind of sounds like a fan but at a higher pitch. There should be a cover on the motor to reduce the noise, maybe it is bent out of shape or just not on right. I need more details
