The printer jammed the paper on the final roller and it is wrapped around it multiple times and i can not reach the edge of the paper to pull it out. can i open the printer somehow to remove the jammed paper??
Most likely, the rollers are worn out. Since this is a consumer grade printer, you will be unable to replace the rollers. You might pull the paper tray and try to clean the rollers with rubbing alcohol. Sometimes this will work, but most the time the wear is enough that nothing will stop the printer from feeding multiple sheets.
