If your Sentry Supreme 5330 safe is not opening, there could be a few possible reasons why:
Combination Error: If you are using a combination to open the safe, make sure that you are entering the correct combination. If you have forgotten the combination, you will need to contact Sentry Safe customer service to get assistance on how to recover or reset your combination.
Dead Batteries: If you have an electronic lock on your safe, the batteries may be dead. Replace the batteries and try again.
Jammed Bolts: The locking bolts may be jammed due to incorrect operation or a mechanical problem. Try tapping the safe door gently with a rubber mallet to loosen the bolts and then try to open it.
Mechanical Malfunction: If the safe still does not open, there may be a mechanical malfunction. In this case, you will need to contact a professional safe technician to diagnose and repair the problem.
Note: If you have lost your key, you will need to contact Sentry Safe customer service to order a replacement key.
The best method to get into a safe when the combination is lost will depend on which safe you have. You can try to get into the safe by getting an override key, having a locksmith make a key, retrieving the code to the safe from the manufacture, breaking into the safe, or drilling the safe open professionally.
https://www.acmelocksmith.com/blog/i-lost-my-safe-combination/
Hi I have a safe which is locked it won't open with the right combination. The buttons won't press in either. Also I have missed placed my key. The number is 701/5359
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
Only way.Did u register the safe product when u buy this thing,yes call Honeywell.They will give u their secret master combination numbers if they trust u or they'll sent out to u a safe tech. service rep. to ur house used that combinations.
The serial number is of no use. If you could obtain the combination simply by asking on a public website then your safe would be, by definition, an unsafe... Many electronic safes come with an emergency bypass key, so check that you haven't got one ferreted away somewhere.
If you have forgotten the combination and have no bypass key then the only option is to cut or drill the safe open. You can call out a locksmith if you like, but will find that the only difference is that he/she may have better tools and safety equipment than you and will have a better idea where to cut. Some cheap, pressed steel, safes with plastic front combination panels can be opened even more easily by just hammering off the plastic bits until access can be gained to the sliding door bolt mechanism.
Sorry that this is not the answer you were hoping for, but safes are not meant to be easy to open other than by using the correct key or combination.
just boughy it and instructions got thrown away by accident . I have keys but no combination please advise..... Numbers on door that are tagged on is: BJ-285913* an another sticker that says 50310 BJ285913 please advise...
