Question about LG LRFD25850 French Door Refrigerator
LG LRFD25850 French Door Fridge set at 37-40 c keeps freezing produce at back or in large bottom drawer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 161 Answers
Pull the drawers put and cover the cold air vent (small hole at back wall) with tape ...problem solved!
Posted on Jan 24, 2010
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
Bottom freezer has stopped working efficiently as a freezer (now fridge temp) all food defrosted, . Previous to this freezer was icing up, ice would fall out when you opened up the drawer. Please help
these machines use thermosistor a solid state temperature reactive transistor devices.
they do not seem to continue to work well. please check to see if the refrigerator is in warranty or, return it if you can or, you can join the class action suit against LG
Jul 31, 2010 | LG LRFD25850 French Door Refrigerator
Have set fridge at 46 degrees yet salad veggies still freeze in the compartments. How can I fix this?
Remove the bottom drawers and locate the vent small round hole. cover it with a piece of sturdy tape...problem solved.
Nov 03, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG French Door Fridge LRFD25850 has error code dh. What to do? What does this mean?
LG Customer Service said to unplug the fridge for 1/2 hour and it should reset itself.
Sep 08, 2009 | LG LRFC25750 Refrigerator French Door
Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Freezer cold/fridge warm
You have a defrost issue and needs to be serviced by a qualified LG technician.  The freezer fan motor is blocked by a large chunk of ice behind the rear panel of the freezer section.  You will need to remove the rear panel to get access to the fan and get rid of the ice.  This will get your refrigerator working again but this problem will return.  You will need to have your control board replaced.
May 10, 2008 | LG LRFD25850 French Door Refrigerator
LG LRFD25850 French Door Refrigerator Logo
320 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
