Jenn-Air JGW8130A Electric Single Oven Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After cleaning my oven and letting it cool it still won't open
Anonymous
Level 2:
  • Expert 262 Answers
  • Posted on Jan 07, 2010
Anonymous
Expert
Level 2:
Answers
262
Questions
Helped
75253
Points
802
Turn off the house breaker to the machine for about 15 minuts and turn it back on and see if it releses the door. or unplug the machine for the same amount of time.
If this does not work then your Oven latch may be bad. I looked up your latch and it is a motor drive latch.
One more thing that could be bad is the TOC or sometimes call the High limit thermo fuse.
1helpful
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 • Ovens
My general electric XL-44 will not go out of self cleaning position after my using it to clean my oven.please help
Let it cool down completetly only then the lever is released to open the door. Or open the top hood of the oven reach for the switch and release the catch to operate the lever to open the door.
Nov 30, 2013 • Ovens
1helpful
2answers
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 • Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 • Ovens
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
1helpful
Door locked after self clean cycle.
Ensure you let the oven cool down completely after a clean cycle before trying to open the door.
If the door still won't open after a couple hours of cooling down, then go to the main power panel in your house and shut off the breaker to the oven. Leave it off for 5 minutes, then switch it back on again.
Then try the oven door again.
Good luck.
I have the self cleaning feature and put it on medium clean which takes 3 hours. This was 4 hours ago and the oven is still hot and the door won't open
This is normal, don't panic! You have to let it cool off. Cool down can take up to 2 hours (after the clean cycle is done). The companies do not factor in cool down time into the length of the clean cycle. The oven reaches about 750 to 800 degrees during self clean so give it some time.
I ran the cleaning cycle on my Jenn-Air oven today, and the locking lever is stuck in the lock position and won't open. The oven is completely cool and the lock light is off. Any suggestions?
did you let the cycle complete and cool down or did you force it open the oven is still locked and you will have to force the lock and adjust the lock for it to open normal in the future
Oct 17, 2009 • Ovens
Kitchenaid superba oven stovetop oven door will not open after se
When the oven goes into clean mode the door is automatically locked as a safety feature. I would put it back into clean mode again, let it clean for a while and then hopefully when it cools down the door will open. good luck .
Mar 20, 2009 • Ovens
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
