Intermatic WH 21 timer will not turn off. The spring for the off mechanism was broken and I repaired it. Timer turns on but will not turn off when tripper passes by.
SOURCE: The Trippers on my Paragon Electric timer are
The following Web Site lists tripper pins for Paragon timers. I don't know if your model is listed, but give it a try.
I hope this helps!
http://www.icca.invensys.com/paragon/parts_accessories.htm
SOURCE: Need tripper pins for AMF Paragon Timer Model 7218
Go to electricalexpeditors.com for replacements.
SOURCE: Replacement of on/off trippers for intermatic low voltage timers
These should work:
http://www.nextag.com/timer-trippers/shop-html
SOURCE: The spring that turns off
Parts are not available for WH21 240V water heater timer.
Timer has 1 year limited warranty.
http://www.intermatic.com/customer%20service/frequently%20asked%20questions.aspx
WH21 is rated for 25Amps and works on water heaters up to 4500Watts.
Look at label on side of tank to see wattage.
WH21 is SPST and turns off one hot wire to water heater.
I ran a business for many years.
Cost of stocking, organizing, and shipping parts is near same cost as new timer.
Following page shows selection of replacement timers:
http://waterheatertimer.org/Boxtype.html
For example, I have tested WH40 and T104 and other timers that show on page.
Trippers and motors are available for Intermatic box timers WH40 and T104, so you can maintain these specific models for many years.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
WH40 and T104 timers are SPDT and turn off both hot wires to water heater.
Both timers will work on any wattage residential water heater
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
