SOURCE: spoiled meat thawed in freezer,
thats a terible smell too if its a frost free you may have to take the inside panels apart and clean behind it also on the self defrost mod.their is a drain pan under or in the back that would have filled with nasty juices dan
SOURCE: Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
SOURCE: refrigerator has spoiled meat odor. Can't find
drip tray is under unit remove toekick and check if pan heater is connected
SOURCE: fridge & freezer not cooling. Meat thawing
If the refrigerator isn't cool, you need to answer
some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's
stopped completely.”
Is the thermostat knob turned to the proper setting?
If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no
apparent moving parts. It's on the outside of the refrigerator at the
back near the bottom. If it is humming or making a continuous noise and
your refrigerator is still not cooling, there may be a more serious
problem with one or more of several different components, we recommend
contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have
power to the refrigerator, there may be a problem with one or more of
these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
